How is electrical potential transmitted through an electric circuit
The discussion centers on how electrical potential is transmitted through an electric circuit, exploring the mechanisms of potential energy storage in electrons and the relationship between electric potential, current, and energy. Participants examine analogies with other systems, such as gravitational and gaseous systems, to clarify concepts related to electrical potential and energy transfer.
  • Some participants propose that electrical potential is transmitted through the movement of electrons, with more electrons contributing to greater potential energy.
  • Others argue that electric potential is independent of the number of electrons and is defined as energy per unit charge (voltage), with each electron carrying the same charge.
  • A later reply questions what differentiates electrons at different potentials, likening it to balls at different heights in a gravitational field.
  • One participant suggests that potential energy in an electrical system is analogous to gravitational potential energy, with electrons having potential based on their position in an electric field.
  • Another participant asserts that electrons do not store potential energy; rather, potential energy is associated with the forces acting on them in a field.
  • Some participants discuss the implications of conservative versus non-conservative forces in the context of electric circuits and potential energy.
  • There is mention of how electric potential energy can be understood through analogies with gravitational systems, emphasizing the role of position in an electric field.
Participants express differing views on whether electrons themselves store potential energy and how electric potential relates to the number of electrons and their movement. The discussion remains unresolved, with multiple competing views presented.
Limitations include varying interpretations of potential energy in different contexts, the dependence on definitions of electric potential, and the complexity of conservative versus non-conservative forces in electric circuits.
Quercus
My question is how is electrical potential actually transmitted through an electric circuit.
A charge (i.e. and electron) is moved through an magnetic field (as in a generator), the particle gains electric potential due to the work performed on it in the generator. This potential is then used elsewhere in a circuit (e.g. a motor or transformer) to do useful work.
How is the potential acually stored in the electron? If this were a gaseous system, the potential would be represented as an increase in pressure, manifested as higher temperatures and tighter packing of the molecules. If this were a physical system, the potential energy might be manifested as balls lifted higher in a gravitational field, capable of doing work as the fall.
What is the mechanism for our electron? Faster motion or increased vibration?
Thanks.
Hmm, I say it's by the movement of electrons throughout the circuit. The more electrons that are pushed through the circuit, the more potential energy it has. So, the more voltage you supply to the circuit, or the larger the battery, the more potential energy it has.
I say that a single electron stores potential energy by it's velocity, but with circuits, we're talking about tons and tons and tons of electrons moving at the same velocity, so it's the amount of electrons that account for the potential energy.
Thanks for the thoughts, but electric potential is not related to the amount of electrons. The electric potential is measured in V (volts) which is joules per coulomb or energy per unit charge. Since each electron has the same charge, this is the equivalent to saying energy per electron. The amount of charges (electrons) is the current, I, in coulombs per second. In an electrical circuit, you can use a transformer to convert a large amount of one into a large amount of the other, but they are two separate things.
Thinking back to the ball example, the potential (voltage) is the height that we have lifted our ball. The current is the quantity of balls that we have lifted. You can use two balls lifted to a height of one meter to lift a single third ball to a height of two meters.
So you can have two wires, each carying one amp of current, but one wire is at one volt, and the other at two volts (relative to ground). Both wires are transporting the same quantity of electrons, but the electrons in the two volt wire each contain twice as much energy as the electrons of the one volt wire.
What I want to know is what is different about these two volt electrons that acutally gives them more energy?
Two electrons at different electric potential differ as much as two identical balls at different height. The balls are at points of different potential in a gravitational field, the electrons are at points of different potential in an electric field. You can imagine mass as "gravitational charge". Charges get potential energy in a field. If they move in the field between points of different potential the potential energy difference will be transformed into other kind of energy - kinetic energy, heat...
ehild
Energy is simply motion ( with mass) , therefore if there is more energy there is more motion , this maybe due to speed ( average ) or due to amount , as you say voltage is energy PER unit charge there fore it implies higher motion of the charge ( electron ) -- so I think you have answered your own question. Ray
Vibration ( spin ) or whatever is a different matter in electronics we are dealing with translational energy and losses due to interaction with the sub lattice ( heat ).
This is an electrical system; potential is stored in the electron by the electron being at a location that has a certain electrical potential. To use your words, electrons are lifted "higher" in an electrical field, capable of doing work as they fall in this electrical potential. It is exactly analogous to gravity, except that charges are either sign and forces can be attractive or repulsive, whereas mass is one sign and force there is always attractive.
First of all, electrons do not store potential energy. If an electron is in a force field, then at every (appropriate) point in space there is a specific force -- electrical, gravitational, magnetic, ... --- which acts on the electron, and which is generated, solely, by some source -- generator, battery, charge complex, matter complex, ... For conservative forces, there is, by definition, a well defined potential, precisely specified modulo a constant.
Then, there are non-conservative forces. For example, in a time-varying E&M situation, the electric field is generated by a time-varying magnetic field, as well as, posssibly by a charge complex.
The thing to remember is simply: for a current to exist, there must be a force acting on the charge carriers. If the force is conservative, there's a well defined potential. If not, then the force is classified as an electromotive force. All of this is usually discussed in exquisite detail in freshman physics books -- batteries, generators, maybe more subtle situations like thermocouples, piezoelectric effects, and so forth.
Often, electric circuits afford a student's first experience with non-conservative forces (other than friction) Tricky, but most get the ideas after a bit of study.
Regards,
Reilly Atkinson
I always get that confused, thanks for the explanation Quercus. Ok, the electric potenital energy depends on the position of the electron in an electric field, the same way the potential energy of the ball depends on the height of the ball above the Earth's surface.
Ex: Take a uniform electric field and point it down and put a positive test charge into the field...similar to a ball in the Earth's gravity field. If you move the test charge up, the E-field does negative work on the charge, so the charge gains potential energy, the same way the ball gains potential energy when it's raised up.
  • · Replies 21 ·
11K
  • · Replies 16 ·
