Solve for Average Velocity during 2nd Half of Trip
The average velocity required during the second half of a trip, given an average velocity of 14.0 m/s for the first half and a desired overall average of 24.0 m/s, is 20.0 m/s. The correct formula to use in this scenario is v = 2(V_av - v_o), where V_av is the overall average velocity and v_o is the initial average velocity. The calculations demonstrate that regardless of the total distance, the average velocity for the second half remains constant at 20.0 m/s to achieve the desired overall average.
  • Understanding of average velocity calculations
  • Familiarity with the formula v = 2(V_av - v_o)
  • Basic knowledge of distance, speed, and time relationships
  • Ability to manipulate algebraic equations
  • Study the derivation of average velocity formulas in physics
  • Learn about the implications of varying distances on average speed calculations
  • Explore real-world applications of average velocity in different contexts
  • Investigate other types of averages, such as geometric and harmonic averages
Students in physics, educators teaching kinematics, and anyone interested in understanding average velocity calculations in motion scenarios.
ffrpg
Here's the problem, While Traveling through the first half of the distance of the trip, your average velocity is 14.0 m/s. What average velocity would you need during the second half of the distance on your trip, if you wanted your average velocity for the entire trip to be 24.0 m/s.
Here's what I did. I used the formula V_av = 1/2(v_o+v). I plugged in 24.0 m/s into V_av and plugged in 14.0 m/s into V_o. I solved from there and got 34.0 m/s. That isn't the right answer. Did I use the right formula? Is there a way to express the time for the first and second half of the trip?
No, you didn't use the right formula. The idea of any "average" (and there are many different kinds) is that you can use the average in place of al the original numbers. The "arithmetic average" is a single number by which you can replace all the other numbers and get the same SUM- that's the one that gives (x+y)/2 as the average of x and y. (If you were concerned with products, you would use the geometric average.)
Since you are talking about speed, the "average" speed for the entire trip is the speed such that, if you traveled at that speed only, you would cover the same distance as you actually did.
In this problem you are told that the average speed for the first half of the trip is entire trip is 14 m/h. You want the average for the entire trip to be 24 m/h. What must your average speed be for the entire trip.
Assume, for now, that the entire trip covers 240 mi. The first half, then, is 120 miles. At 14 m/h, that takes 120/(14 m/h)= 60/7= 8 and 4/7 hours. You want to average 24 m/h for the entire trip. Okay, that means the entire trip must take 240/24= 10 hours. You have 10- 8 4/7= 1 3/7= 10/7 hours in which to cover the second 120 miles: that's an average of 120/(10/7)= 12*7= 84 m/h!
Notice I said "assume 240 mi." How do we know the answer wouldn't be different if the entire trip were a different distance? We don't until we check. The point of using 240 mi (which I chose simply because it was easily divisible by 24) was that it helped to see what operations we needed to do.
Now suppose the entire trip is A mi. Then half of it is A/2 and, at 14 mph, that will require (A/2)/(14)= A/28 hours. If we average 24 m/h for the entire distance, that will require A/24 hours.
That means we have A/24- A/28= (7A- 6A)/(4*6*7)= A/168 hours in which to do the second half. We have to average (A/2)/(A/168)= 84 m/h.
Yes, that does NOT depend upon A and is the answer we got before. That is the average velocity required.
Your approach is correct, but you may have made a mistake in your calculations. The formula V_av = 1/2(v_o+v) is used to find the average velocity when the initial velocity (v_o) and final velocity (v) are known. In this problem, the final velocity is unknown, so we can rearrange the formula to solve for it: v = 2(V_av - v_o). Plugging in the values, we get v = 2(24.0 m/s - 14.0 m/s) = 20.0 m/s. This means that the average velocity during the second half of the trip would need to be 20.0 m/s for the overall average velocity to be 24.0 m/s.
There is no need to express the time for the first and second half of the trip in this problem. The average velocity can be calculated solely based on the initial and final velocities. However, if you wanted to find the time for each half of the trip, you could use the formula t = d/v, where d is the distance and v is the average velocity. You would need to know the distance of the entire trip and the average velocity for each half in order to find the time.
  • · Replies 17 ·
9K
