How Fast Can Air Travel Through a 2.5 Inch Pipe at 14.7 PSI?
This discussion focuses on calculating airflow through a 2.5-inch diameter pipe at a static pressure of 14.7 PSI and the time required to compress the air to 20.7 PSI. Using Bernoulli's equation and the volumetric flow rate formula Q = (π/4) x D^2 x V, the maximum airflow velocity is determined to be approximately 8.99 meters per second. Additionally, applying the ideal gas law, the time to compress the air to 20.7 PSI is calculated to be approximately 0.084 seconds, assuming standard conditions and 1 mole of air.
  • Understanding of Bernoulli's equation
  • Familiarity with the ideal gas law (PV = nRT)
  • Basic knowledge of volumetric flow rate calculations
  • Ability to convert units (inches to meters, PSI to appropriate units)
  • Learn advanced applications of Bernoulli's equation in fluid dynamics
  • Study the ideal gas law and its implications in real-world scenarios
  • Explore the effects of pipe length and diameter on airflow rates
  • Investigate the impact of temperature variations on gas compression times
Engineers, physicists, and students studying fluid dynamics or thermodynamics, particularly those interested in airflow calculations and gas compression principles.
synapicphysic
Given: you've got a 2.5 inch diameter pipe ... how much air can flow thru the pipe at stoic pressure (14.7)?
slightly harder (I think) ... this pipe is 6 ft long, how long would it take to compress the air inside the pipe to 20.7psi, and what would airflow be?
This sounds like a homework problem and depends an awful lot on how complicated you want to get with your calcluations. For a start though, use Bernouli's equation, use 14.7psi as you dynamic pressure and calculate the velocity.
The second question doesn't give enough information.
The maximum velocity of airflow in a pipe is dependent on several factors such as the diameter of the pipe, the pressure of the air, and the length of the pipe. In this case, we have a 2.5 inch diameter pipe and a stoic pressure of 14.7 psi. To calculate the maximum airflow, we can use the equation Q = (π/4) x D^2 x V, where Q is the volumetric flow rate, D is the pipe diameter, and V is the velocity of airflow.
Plugging in the values, we get Q = (π/4) x (2.5 inches)^2 x V. Converting the diameter to meters (2.5 inches = 0.0635 meters), we get Q = (π/4) x (0.0635 meters)^2 x V. Rearranging the equation to solve for V, we get V = (4 x Q)/π x D^2. Plugging in the given stoic pressure of 14.7 psi, we get V = (4 x 14.7 psi)/π x (0.0635 meters)^2. This gives us a maximum velocity of approximately 8.99 meters per second.
For the next part of the question, we need to determine the time it would take to compress the air inside the pipe to 20.7 psi. To do this, we can use the ideal gas law, PV = nRT, where P is the pressure, V is the volume, n is the number of moles, R is the gas constant, and T is the temperature. Assuming the temperature remains constant, we can rearrange the equation to solve for time (t = (P2-P1) x V/(nR)), where P2 is the final pressure (20.7 psi) and P1 is the initial pressure (14.7 psi).
Plugging in the values, we get t = (20.7 psi - 14.7 psi) x (6 ft x 0.0635 meters/ft) / (n x 8.314 J/mol·K). Assuming the air inside the pipe is at standard temperature and pressure, we can use n = 1 mol. This gives us a time of approximately 0.084 seconds to compress the air inside the pipe to 20.7 psi.
Finally, to calculate the new airflow at the increased pressure,
  • · Replies 21 ·
10K
