Does the Moment of Inertia Change When a Gyroscope is Lifted?
The discussion centers on the experiment conducted by Daniel, which investigated the precession and nutation of a gyroscope. The gyroscope's moment of inertia about the x-axis was calculated using the formula Ix = 0.5MR², where M is the mass and R is the radius of the disc. While initial measurements aligned with theoretical predictions, subsequent tests at various angles of inclination revealed inconsistencies, prompting the question of whether the moment of inertia changes when the disc is lifted. The consensus suggests that the moment of inertia does indeed change as the angle of inclination alters the distribution of mass relative to the pivot axis.
  • Understanding of gyroscopic motion and principles
  • Familiarity with torque and angular momentum concepts
  • Knowledge of moment of inertia calculations
  • Basic physics laboratory measurement techniques
  • Research the effects of angular displacement on moment of inertia
  • Explore advanced gyroscopic dynamics and stability analysis
  • Learn about the mathematical derivation of precession formulas
  • Investigate experimental methods for measuring angular momentum
Physics students, educators, and researchers interested in gyroscopic motion, torque dynamics, and experimental physics methodologies.
Daniiel
Hey
I just finished an experiment in my physics lab where we examined the precession and nutation of a gyroscope.
The gyroscope was built with a shaft which had a pivot in the middle, on one end of the shaft the large spinning disc was placed and on the left side of the shaft counterweights were placed.
Torque was applied on the side of the large spinning disc, firstly the shaft was kept horizontal and several measurements were made (the angular precession frequency and the angular frequency of the spinning disc) then a relationship was developed and compared to a formula we were provided. This formula was wpr = T/(Ix wx)
Where T is torque r x F, Wpr the precession frequency, Wx the spin frequency and Ix the moment of inertia about the x-axis which was 0.5MR2 where M is the mass of the disc, R is it's radius.
Our results fit well this the equation provided and everything seemed correct.
We then examined the effect of changing the angle of inclination, so took the measurements again with the disc raised at various angles. The results obtained were not consistent with the formula provided.
My question is, does the moment of inertia about the x-axis change when the disc is lifted, and if so does it decrease?
I would think it does change since at the horizontal everything is at its furthest apart positions, then when the disc is lifted above the horizontal everything moves closer towards the axis of the pivot, kind of hard to explain that sorry.
Here's a terribly drawn picture of the apparatus:
http://img198.imageshack.us/img198/4884/gyroscope.jpg
But yea, thanks in advanced,
Daniel
I'm sure you took into account that rxF is not a constant?
Yea we did,
Do you think its correct to think that Ix changes?
  • · Replies 49 ·
  • · Replies 0 ·
  • · Replies 18 ·
