How Does Permuting Eigenvectors Affect Matrix Representations?
  • Context: Graduate
  • Thread starter Thread starter Cylab
    Decomposition Matrix
The discussion focuses on the impact of permuting eigenvectors on matrix representations, specifically in the context of diagonalizable and non-diagonalizable matrices. It establishes that permuting the sequence of eigenvectors, denoted as p1, p2, p3, ..., pr, results in a diagonal matrix that remains similar to the original matrix. For non-diagonalizable matrices, the use of generalized eigenvectors is necessary, which leads to the formation of Jordan blocks in the Jordan canonical form. The significance of permuting eigenvectors lies in the rearrangement of matrix representations while maintaining similarity.
  • Understanding of eigenvectors and eigenvalues
  • Familiarity with diagonalizable matrices
  • Knowledge of Jordan canonical form
  • Concept of generalized eigenvectors
  • Study the properties of diagonalizable matrices and their eigenvectors
  • Learn about Jordan canonical form and its applications
  • Explore the concept of generalized eigenvectors in linear algebra
  • Investigate matrix similarity and its implications in transformations
Mathematicians, linear algebra students, and anyone involved in advanced matrix theory or applications requiring an understanding of eigenvectors and matrix representations.
Cylab
A = PD[P][/-1];
A: square matrix;
D: is a matrix of Jordan canonical form
P:is EigenVectors..(p1,p2,p3,p4...pr)
Is it possible to permute the sequence p1,p2,p3,p4...pr into other form?
I know it should be possible to permute...
How should permute it and what significance it has?
Why is it essential to permute vectors/matrix?
Thanks in advance for your attention.
If an n by n matrix is "diagonalizable", that means it has n independent eigenvectors and so if you use those eigenvectors as basis vectors will give a diagonal matrix representing the same linear transformation as the original matrix- the two matrices are "similar". Changing the order in which you use the eigenvectors will give a diagonal matrix with the number on the diagonal in different places, but they will still be similar to the original matrix and so to each other.
If a matrix is not diagonalizable, it does not have a "complete set" of eigenvectors- you can not have a basis for the vector space consisting entirely of eigenvetors. But you can, by using "generalized eigenvectors" (v is a "generalized eigenvector" corresponding to eigenvalue [itex]\lambda[/itex] if it is NOT true that [itex]Av= \lambda v[/itex] but it is true that Av is an eigenvalue or another generalized eigenvector.) The eigenvector and generalized eigenvectors corresponding to a given eigenvalue give the "Jordan" blocks in the Jordan Normal form. Changing the order of those will give a matrix with the rows and columns rearranged and so not in "Jordan Normal Form", but still "similar" to such a matrix.
  • · Replies 23 ·
  • Poll Poll
  • · Replies 62 ·
13K
