The Bob
- 1,127
Hi All,
Just want you to double check my method and result for a question that I thought of.
What is the area of a regular pentagon?
I divided the pentagon into three isosceles. Two triangles, the two on the sides if the base is on the bottom, have two sides which are 200m each and an unknown side with the angles 108°, 36° and 36°. The middle triangle has the base as 200m and the angles as 36°, 72° and 72°.
So applying the Cosine Rule the two sides will be:
a² = b² + c² - 2bc cosA
a² = 200² + 200² - [(2 x 200 x 200)(cos 108°)]
a² = 4000 + 4000 - (80000 x -0.309)
a² = 8000 + 24721.35
a² = 32721.35
a = (square root)32721.35
a = 180.89m
Then work out the perpendicular height of the triangle:
Sin = Opp/Hyp
Sin 36° = y/200
Sin 36° x 200 = y
y = 117.56m
Then work out the area of the triangle:
1/2 (117.56 x 180.89) = 10632.47m²
The middle triangle:
The perpendicular height:
Sin = Opp/Hyp
Sin 72° = y/180.89
Sin 72° x 180.89 = y
y = 172.03m
Area of triangle:
1/2 (200 x 172.03) = 17203.7m²
Total Area: (10632.47 x 2) + 17203.7 = 27836.17m²
If you have time to check then please do but I just want a double check.
Cheers.
The Bob (2004 ©)
a² = 32721.35
a = 180.89m
Sin = Opp/Hyp
Sin 36° = y/200
Sin 36° x 200 = y
y = 117.56m
Sin = Opp/Hyp
Sin 72° = y/180.89
y = 172.03m
Area of triangle:
Cheers.
The Bob (2004 ©)
