Solving for Tension in Masses Connected by String Over Pulley
The discussion focuses on solving for the tension in a system of two masses, m_1 and m_2, connected by a massless string over a frictionless pulley. The acceleration of the masses is determined to be a = m_2 * g / (m_1 + m_2). Key equations include T_1 = m_1 * a for the upper string tension and T_2 - m_2 * g = m_2 * a for the lower string tension. The presence of a pulley with mass m_p and radius R introduces additional complexity, requiring the use of torque equations and rotational inertia to solve for the tensions and acceleration in the system.
  • Understanding of Newton's Second Law
  • Familiarity with torque and rotational motion
  • Knowledge of mass and acceleration relationships
  • Basic grasp of systems of equations
  • Learn how to derive rotational inertia (I) for different shapes
  • Study the no-slip condition and its implications in pulley systems
  • Explore solving systems of equations in physics problems
  • Investigate the effects of friction in pulley systems
Physics students, mechanical engineers, and anyone studying dynamics and kinematics of connected mass systems.
quick
Blocks of mass m_1 and m_2 are connected by a massless string that passes over the frictionless pulley in the figure. Mass m_1 slides on a horizontal frictionless surface. Mass m_2 is released while the blocks are at rest.
http://s93755476.onlinehome.us/stuff/knight.Figure.13.68.jpg
i know the acceleration of the masses is m_2*g/(m_1+m_2)
i need to find:
A. the tension of the string
B. supposing the pulley has mass m_p and radius R. Find the acceleration of m_1 and the tensions in the upper and lower portions of the string.
C. find the tension in the upper portion of the string.
D. find the tension in the lower portion of the string.
i know T_1 (upper portion of string) is T_1 = m_1*a
T_2(lower portion) is T_2 - m_2*g = m_2*a
torque = T_2*R - T_1*R = I*alpha
i still don't know how to solve for the tension of the string since there are two different tensions on the string depending on the pulley. i tried adding the two tensions but that didn't work. I am not really sure how to incorporate mass of the pulley. any help is appreciated.
You need to be careful here, because these two equations contradict each other. The first says that block 1 is moving to the right (and therefore block 2 is moving down), and the second equation says the exact opposite. I'd rewrite the second equation to read:
m2g-T2=m2a.
You're not supposed to add the tensions. You're supposed to solve the 3x3 system of equations that you have. Your 3 unknowns are T1, T2, and a.
im not really sure how to incorporate mass of the pulley. any help is appreciated.
Look at your torque equation:
The mass of the pulley appears in I, the rotational inertia. Also make the substitution: alpha=a/R (the no-slip condition).
I assume you have no problem solving for the tension in Part A, right? (Part A apparently assumes that the pulley is frictionless AND massless.)
For the rest, you need to express I as a function of mass and alpha as a function of a, so you end up with 3 equations and 3 unknowns. (You do realize that a for part B will be different than the a you got for part A?)
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 27 ·
