Confused (simple harmonic motion problem)
The problem involves a block connected to a spring on a frictionless table, which is impacted by a bullet. The goal is to determine the amplitude of the resulting simple harmonic motion after the bullet embeds itself in the block. The context is simple harmonic motion and conservation laws in physics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using conservation of momentum and energy to solve the problem. There is an exploration of the relationship between the bullet and block system and the implications of the collision being inelastic.
The discussion has progressed with participants offering guidance on applying conservation laws. Some participants have clarified the need to consider the bullet-block system and the implications of energy dissipation during the collision.
Participants note that energy is not conserved in the collision due to inelasticity, and there is a focus on the need for sufficient information regarding the masses and velocities involved.
SnowOwl18
Ok I've been trying this problem :
---A 21.0kg block at rest on a horizontal frictionless table is connected to the wall via a spring with a spring constant k=14.0N/m. A 2.10×10-2kg bullet traveling with a speed of 530m/s embeds itself in the block. What is the amplitude of the resulting simple harmonic motion? Recall that the amplitude is the maximum displacement from equilibrium.----
And I thought I could use the equation (1/2)mv^2 = (1/2)kA^2 ...but I got the answer wrong...and the hint says to first use conservation of momentum, and then conservation of energy. It seems like i couldn't do that, since it seems like I don't have enough information. Any help? Thanks :)
That's right. In general, energy is not conserved in collisions, but momentum is.
You do have enough information. You know the mass of the bullet (m) and the mass of the block (M). You also know the initial velocity of the bullet (vi), and you want to know the final velocity of the bullet+block system (vf).
Can you write the law of conservation of momentum in terms of those symbols?
Oh my bad...I wasn't thinking of the bullet block system. Thank you..I'll try that and see if it works.
well, since the collision is not elastic (the bullet sticks), PE+KE energy is not conserved (dissipated into sound, block heating up/breaking and so forth). so you should calculate the velocity of the system after impact using conservation of momentum and then use this new velocity to determine the energy that must be equal to kA^2/2
oh i got it, thanks!
  • · Replies 51 ·
