New Reply
Projectiles: Launch speed and horizontal distance
Share Thread Thread Tools
Sep14-11, 07:27 PM   #1
New to the forums, just starting a physics 11 course online and having some troubles with formulas.
Projectile shot straight upwards, flight time = 4.70 sec
Second Launch at 45 degrees (horizontal range approx. 50-60 meters
A) Find Launch Velocity
B) Find Horizontal Range when shot at 45 degrees
2. Relevant equations
d = vit +1/2gt2
V = - 1/2gt ("made" this one myself from above formula, unsure if correct)
3. The attempt at a solution
Launch velocity
V = - 1/2gt
g = -9.8m/s
t = 4.7s
V = -[((1/2(-9.8))(4.7)]
V = -((-4.9)(4.7))
V = 23.0 m/s
I have no idea how to calculate the horizontal range, I need a formula that incorperates the 45 degrees
Thanks in advance!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep14-11, 07:38 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by gratsoy View Post
d = vit +1/2gt2
Launch velocity
V = - 1/2gt
g = -9.8m/s
t = 4.7s
V = -((-4.9)(4.7))
V = 23.0 m/s
Thanks in advance!
You can work from first principles: Calculate the vertical and horizontal components of the launch speed - using sin45 and cos 45 factors.
The vertical component lets you calculate the flight time, the horizontal component with that time lets you calculate how far away it will land - the range.
Many Physics texts will have a section where a formula is derived, so you can simply substitute the 23 m/s to get an answer [assuming 23 m/s is correct - it certainly is a reasonable answer]
Sep15-11, 06:46 PM   #3
Quote by PeterO View Post
How would I do this? I am completly new to this and need a formula with a simple step-by-step guide on how to implement that formula to derive the answer.
New Reply
Tags
angle, horizontal distance, launch velocity, velocity
Thread Tools
Similar Threads for: Projectiles: Launch speed and horizontal distance
Thread Forum Replies
Find launch speed given spring constant and compressed distance Introductory Physics Homework 1
Horizontal velocity required to launch into orbit? Introductory Physics Homework 3
Projectile Motion - Horizontal Launch Introductory Physics Homework 7
Launch angle and Projectiles Introductory Physics Homework 1
Relative speed: Horizontal distance travelled in a collision Introductory Physics Homework 3
