Lab concerning Inverters experiement
  • Thread starter Thread starter Petenerd
    Lab
The discussion focuses on conducting a lab experiment using the 7404 hex inverter IC, along with 6 LEDs and 150Ω resistors. The lab involves wiring the components so that alternating LEDs light up based on the position of a logic switch. In position 1, LEDs 1, 3, and 5 illuminate, while in position 2, LEDs 2, 4, and 6 light up. The schematic diagrams referenced provide circuit configurations that illustrate the connections between the switch, inverter, LEDs, and resistors, with specific pin references for the IC provided in the datasheet.
  • Understanding of digital logic circuits
  • Familiarity with the 7404 hex inverter IC
  • Basic knowledge of LED wiring and resistor usage
  • Ability to read and interpret circuit schematics
  • Review the 7404 hex inverter datasheet for detailed specifications
  • Experiment with different configurations of LEDs and inverters
  • Learn about Boolean expressions and their applications in digital circuits
  • Explore additional logic gate ICs for more complex circuit designs
Electronics students, hobbyists working on digital logic projects, and educators conducting lab experiments involving inverters and LED circuits.
Petenerd
I have to conduct a lab concerning inverters. I'm using a 7404 hex inverter IC, 6 LED's with 150Ω resisters, and 1 logic switch. Can someone tone it down a little bit so I can undersetand what the lab is wanting me to do? And what does the image on the second page show (Figure 3-7 and 3-8)?
For table 3-6: 1, 0 going down. Questions: (2.) 0 (3.) 0 (4.) logical 1 (5.) Boolean expression not A means A is inverted.
All you're doing is wiring up the LED's and 7404 so that every other LED is lit. In switch position 1, LED's 1, 3 and 5 light. In position 2, LED's 2, 4 & 6 light.
Not really comparable in difficulty to the Millikan oil drop experiment ... :-)
Your answer to question 4 assumes a logical 1 input. You could say that the logical state of the output will be the logical state of the input.
The images are schematic diagrams which show 2 circuit configurations. I see an input terminal for a switch, an inverter, a LED, and a resistor on the first diagram, same on the second diagram, but with multiple inverters and LEDs. The numbers near the input and output of each inverter give you a reference to a specific pin on the IC.
You should familiarize yourself with the datasheet: http://www.onsemi.com/pub_link/Collateral/74HC04.REV1.PDF
12K
13K
