| New Reply |
Calculating how fast a motor can move something in horizontal motion |
Share Thread |
| Sep17-11, 02:45 AM | #1 |
So I need a motor for a project. The motor i'm looking at creates circular motion. I want to make the motor move some object in a horizontal motion but I want to know how fast it can move the object horizontally before getting it. How can I find out how fast the motor can move it? Motor in mind: http://www.servodatabase.com/servo/hitec/hs-322 Sorry if there are unnecessary unit conversions. Seems like engines are explained in imperial units. 2. Relevant equations Using this equation to find horsepower = (Torque x Engine speed (rpm)) / 5,252 = Horsepower Found from:http://www.howstuffworks.com/question622.htm Torque for engine = 3.70 kg*cm = 0.03 kg per m = 0.22 lb/ft speed = 0.15 sec/60° (not really sure what this is? Assuming 60 degrees every .15 sec. So one revolution (360 degrees) = 0.15 sec x 6 = .90 sec. Then rpm = 66.7 Mass of object being rotated =0.2 kg 3. The attempt at a solution One way I thought of calculating this was converting the torque output to Power then converting power to work then to kinetic energy to velocity. Horse power = 0.22 * 66.7 /5252 = .0028 horse power Mechanical horse power = 33,00 lb*ft/min so (0.028 * 33,000)/60s= 1.54 lb*ft =2.09 n*m I'll assume all work will equal KE. 2.09 J = 0.5 *0.2*v2 V= 4.6m/s. Does it look right? Any help would be appreciated. |
| Sep17-11, 03:49 PM | #2 |
Think about this: you said 'horizontal' motion. What if anything limits the velocity if you continually apply a certain amount of power to a mass moving horizontally?
BTW on the rhs equation of 'mechanical horse power' the dimension is energy, not power, so I would check that. Always check dimensions on any work you do. Every single term. I find more mistakes I make that way than with any other, by a mile! |
| Sep17-11, 07:17 PM | #3 |
| New Reply |
Similar discussions for: Calculating how fast a motor can move something in horizontal motion
| Calculating vertical and horizontal components in projectile motion at a certain time | Introductory Physics Homework | 3 | ||
| How to Change a Horizontal Vector to Move in a 45 degree angle | Introductory Physics Homework | 6 | ||
| How fast does the planets move away from the Sun ? | Astrophysics | 0 | ||
