Inverse of exponential function
The discussion revolves around finding the inverse of the function N=f(L)=1816-8L, with a focus on how to express this inverse correctly for input into Maple software.
  • Participants explore the algebraic manipulation of the function to find its inverse, with some questioning the correctness of the original poster's approach. There is discussion about variable swapping and the simplification of logarithmic expressions.
Some participants have provided guidance on the need to swap the variables L and N to correctly represent the inverse function. Others have noted potential syntax issues in Maple and discussed the simplification of logarithmic terms.
There is mention of constraints related to an online test format and the limited number of attempts allowed for submitting the answer. Participants are also experiencing technical issues with the forum interface affecting their communication.
mark187
Give the inverse of this function
N=f(L)=1816-8L
The answer has to be filled in in Maple
N=1816-8L
16-8L=ln(N)/ln(18)
-8L=(ln(N)/ln(18))-16
L=-ln(N)/(8*ln(18))+2
Is this correct?
When i fill this in in maple it's incorrect.
I've really no clue why it is wrong.
L=-ln(N)/(8*ln(18))+2 is the same function as the original. Choose L the independent variable and N the dependent one. (Just exchange L and N).
ehild
Yes it's correct. What are you typing into maple exactly? Your syntax is probably slightly off.
edit: Sorry I didn't notice that you forgot to swap your variables.
thanks! It's also mentioned that it should be simplified as much as possible.
Does that mean that the 8*LN(18) could be simplified to 8*LN(2*9) and more?
It's as simple as it can get, unless you believe [itex]\ln{\frac{1}{x}}[/itex] is more simple than [itex]-\ln{x}[/itex] you shouldn't be changing anything.
[itex]\ln{18}[/itex] is definitely more desirable than [itex]\ln{9\cdot2}[/itex] :wink:
N=f(L)=1816-8L
N=1816-8L
16-8L=ln(N)/ln(18)
Is this correct?
When I let Maple solve the equation for L it gives me exactly what you wrote. Why do you think Maple thinks it is incorrectÉ What type of error message are you receivingÉ
That annoying É is actually a question mark, but when I type it in it gives me that accented E; that only seems to happen when I access this website through Google Chrome!
RGV
RGV
Well, this assignment was given in a little online test.
The point is, that i can't see why the answer was wrong.
I have 2 chances, so for the second change i will try to swap the variables.
  • · Replies 19 ·
