How High Must a Cart Be Released to Safely Complete a Loop-the-Loop?
  • Thread starter Thread starter Naeem
    Spring
The discussion revolves around a physics problem involving a cart of mass M = 500 kg navigating a circular loop-the-loop of radius R = 10 m. The problem requires determining the minimum height from which the cart must be released to safely complete the loop, considering the normal force at the top of the loop must be at least 0.8 times the weight of the cart. The participants explore various aspects of energy conservation and forces acting on the cart during its motion.
  • Mixed
  • Participants discuss the relationship between gravitational force and normal force at the top of the loop, questioning the initial equations presented by the original poster. There are attempts to clarify the role of gravity in the centripetal acceleration and how to modify the equations accordingly.
Some participants have successfully calculated certain parts of the problem, while others express confusion about specific calculations and the application of energy conservation principles. There is ongoing exploration of how to correctly account for forces and energy at different points in the loop, with no clear consensus on the correct approach yet.
Participants note that the height from which the cart is released must include the height of the loop, indicating a potential misunderstanding of the total energy involved. There are also mentions of different interpretations of the forces acting on the cart at various points in its trajectory, particularly at the top and bottom of the loop.
Naeem
Loop-the-Loop
The two problems below are related to a cart of mass M = 500 kg going around a circular loop-the-loop of radius R = 10 m, as shown in the figures. All surfaces are frictionless. In order for the cart to negotiate the loop safely, the normal force exerted by the track on the cart at the top of the loop must be at least equal to 0.8 times the weight of the cart. You may neglect the size of the cart. (Note: This is different from the conditions needed to "just negotiate" the loop.)
Fn = Mv2 /R = 0.8 Mg
v2 = 0.8 R g = 0.8 * 10 * 9.81 = 78.48 m2 / s2
a) For this part, the cart slides down a frictionless track before encountering the loop. What is the minimum height h above the top of the loop that the cart can be released from rest in order that it safely negotiate the loop?
Mgh = 1/2 Mv2
h = v2 / 2g = 78.48 / 2 * 9.81
h = _________4___________ m
b) For this part, we launch the cart horizontally along a surface at the same height as the bottom of the loop by releasing it from rest from a compressed spring with spring constant k = 10000 N/m. What is the minimum amount X that the spring must be compressed in order that the cart "safely" (as defined above) negotiate the loop?
Mgh = 500 * 9.81 * 4 = 1620 Nm
1/2 kX2 = 1620 Nm
X2 = 2 * 1620 / 10,000 = 0.324
X = ________0.569____________ m
c) When the car is descending vertically (ie at a height R above the ground) in the loop, what is its speed |v|?
Mv2 /R = 0.8 Mg
1/2 mv2 = mg (h + R)
v2 = 2 * 9.81 * (4 + 10) = 294.7
|v| = ______8.86______16.57________ m/s
d) At the bottom of the loop, on the flat part of the track, the cart must be stopped in a distance of d = 10 m. What retarding acceleration |a| is required?
v2 = 2ad
a = v2 / 2d = 78.48 / 2 * 9.81 =
|a| = _________4___________ m/s2
I don't know this is what I have done, but the answers seem wrong. Can anybody help here.
At the top of the loop, gravity is acting on the cart in addition to the normal force. Your equations don't seem to include that. You seem to be confusing [tex]v[/tex] and [tex]v^2[/tex] and forgetting that the mass will be going faster at the top of the loop than at the bottom in some of the parts.
The normal force is not the only force contributing to the centripetal acceleration. Don't forget gravity.
So, how do we add gravity here, then, how can we modify the equation, would it be something like this:
Fn = Mv2 /R +mg = 0.8 Mg
At the top of the loop, the vertical forces are:
normal force, Fn = 0.8 mg acting down
weight = mg acting down​
Thus the net force creating the centripetal acceleration (at the top of the loop) is:
[tex]F_n + mg = mv^2/r[/tex]
Got part a, but how do I figure out part b and d.
For part a , I got h = 9 which is correct.
For part b,
Mgh = 500 * 9.81 * 9 = 44145 Nm
1/2 kX2 = 44145 Nm
X2 = 2 * 44145 / 10,000 = 8.829
X = ________2.971____________ m , which is wrong.
The answer to c is 19.3 which is correct.
For part d,
v2 = 2ad
|a| = _________4___________ m/s2, again this is wrong.
Plz help
Naeem said:
For part b,
1/2 kX2 = 44145 Nm
The height h = 9 is the height above the top of the loop that the car must be released from. To find the total energy you must include the height of the loop--an additional height of 2R = 20m.
For part d,
v2 = 2ad
For some reason, you are still using [itex]v^2 = 78.48 m^2/s^2[/itex], which was your incorrect answer for the top of the loop. Find the speed at the bottom of the loop, using the correct total energy. (See above.)
I forgot how to do part d , I know the acc. is 28.44 m/s2, can anybody explain>>>>
Use the same method you used earlier, only this time use the correct velocity at the bottom of the loop. (Hint: find the kinetic energy at the bottom.)
Can anybody help me with part d.
I did:
From Fn + Mg = Mv^2/R
( Fn in my case is 0.5mg)
so,
0.5mg +mg = mv^2/R
Cancelling the m's through out
v^2 = 1.5 *9.81 / 8 = 117.72 ( Note: R is 8 in my case )
Then,
a = v^2 / 2d ( d = 15m in my case )
therefore, a = 117.72 / 2*15
= 3.924 + 2* 9.81
= 23.544 m/s^2 , which is wrong, Am I missing something,,,,
I did:
What makes you think that Fn = 0.5mg? Also, at the bottom of the loop Fn acts up while gravity acts down.
The way to solve this is to figure out the KE at the top of the loop from the information given in the problem (Fn = .8mg at the top of the loop.). Then you can find the KE at the bottom of the loop by conservation of energy.
13K
