Calculating Velocity from Coordinates: Is it Right?
The discussion revolves around calculating velocity from given coordinates and interpreting the relationship between position and time. The original poster presents coordinates and attempts to derive velocity values for a velocity versus time graph.
  • Participants explore the method of calculating velocity by dividing changes in y-coordinates by changes in time. Questions arise regarding the interpretation of "region" in the context of the calculations and whether it refers to specific line segments or any segment of the graph.
The discussion is ongoing, with participants clarifying the method of determining velocity and how to accurately plot the resulting values on a graph. Some guidance has been provided regarding the calculation process and plotting points, but no consensus has been reached on the interpretation of terms used.
The original poster expresses uncertainty about their approach and the terminology used in the discussion, indicating a need for further clarification on the concepts involved.
Crusaderking1
I have the coords (5.0,0.5), (3.9,1.0), etc.(all can be eyeballed because of no slope.)
If I divided y/x = y of velocity vs time graph (sorry, I don't know how else to put it.)
I would get (5.0, 0.1) and respectively (3.9, .256) for the second cords, and these would be for the velocity vs time graph.
I think I am doing it wrong.
You have a plot of y values versus time? To find the slope of this in some region, you calculate delta y and divide it by delta t, where delta y is the change in y, and delta t is the change in time, in that region. This gives you one point to be plotted on your new velocity versus time graph.
When you say same region, do you mean same line segments?
I didn't anywhere say same region. I said some region, meaning any region. :smile:
Each velocity value you determine is best plotted as a point lying above the midpoint of the time segment, delta t, that was used in determining that velocity value.
Ok thanks.
  • · Replies 30 ·
