Calculating Max Ice Production Rate Given kW Input and Temperature Conditions
The maximum ice production rate from liquid water at 0°C is calculated using the formula: Maximum ice production rate = (W/Qh) * 3600, where W is the power input in kW and Qh is the heat transfer rate in kW. Given that 333 kJ/kg of energy must be removed to freeze water at 0°C, Qh is derived as 0.0925 kW. Consequently, for every 1 kW of power input, the maximum ice production rate is 38756.76 kg/h, confirming the efficiency of the icemaker under specified conditions.
  • Understanding of thermodynamics principles, particularly heat transfer.
  • Familiarity with the concepts of power input and energy conversion.
  • Knowledge of the specific heat of fusion for water (333 kJ/kg).
  • Basic proficiency in algebra for manipulating equations.
  • Study the principles of heat transfer in thermodynamic systems.
  • Learn about the efficiency of refrigeration cycles and icemakers.
  • Explore the calculations involved in energy conversion from kJ to kW.
  • Investigate the impact of ambient temperature on ice production rates.
Engineers, thermodynamics students, and professionals in refrigeration and HVAC systems who are interested in optimizing ice production efficiency and understanding the underlying thermodynamic principles.
eku_girl83
Here's my problem:
For each kW of power input to an icemaker at steady state, determine the maximum rate that ice can be produced in kg/h, from liquid water at 0 C. Assume that 333 kJ/kg of energy must be removed by heat transfer to freeze water at 0 C, and that the surroundings are at 20 C.
I know that W = 1 kw, Tc = 0C=273 K, Th = 20C=293 K.
Since the device operates at steady state, W = Qh - Qc.
I also know that W/Qh is less than or equal to (1- Tc/Th)
Could someone give me a hint on where to start with this one? What is the 333 kJ/kg?
Thanks!
The answer is [tex]14.76kgh^{-1}[/tex], is it?
My working is as follow:
[tex]Q_c=mL_f=m(333\times10^3)[/tex]
[tex]\frac{Q_c}{Q_h}=\frac{T_c}{T_h}[/tex]
[tex]\Rightarrow Q_h=m(357.4\times10^3)[/tex]
[tex]W=Q_h-Q_c=m(24.4\times10^3)[/tex]
[tex]1\times10^3=\frac{m(24.4\times10^3)}{t}[/tex]
[tex]\frac{m}{t}=40.98\times10^{-3}kgs^{-1}=147.54kgh^{-1}[/tex]
To calculate the maximum rate of ice production, we can use the following formula:
Where:
W = power input in kW
Qh = heat transfer rate in kW
3600 = conversion factor from seconds to hours
To find Qh, we can use the formula:
Qh = W * (1 - Tc/Th)
Where:
Tc = temperature of the water being frozen (0°C = 273 K)
Th = temperature of the surroundings (20°C = 293 K)
Now, we need to find the heat transfer rate (Qh) in kW. To do this, we need to know the amount of energy required to freeze 1 kg of water at 0°C. This is given as 333 kJ/kg. This means that for every 1 kg of water frozen, 333 kJ of energy is removed.
To find Qh, we need to convert 333 kJ/kg to kW. We can do this by dividing by the conversion factor of 3600 seconds (since 1 hour = 3600 seconds).
So, Qh = (333 kJ/kg) / (3600 seconds) = 0.0925 kW
Now, we can plug in the values into the formula for maximum ice production rate:
Maximum ice production rate = (W/Qh) * 3600 = (1 kW / 0.0925 kW) * 3600 = 38756.76 kg/h
Therefore, for every 1 kW of power input, the maximum rate of ice production from liquid water at 0°C is 38756.76 kg/h.
  • · Replies 16 ·
