Calculating the dead load of a mild structural steel
The discussion focuses on calculating the dead load of a mild structural steel beam with a solid square cross-section of 100 mm, supported 3 m apart. The ultimate bending strength is given as σb = 450 N/mm², and the ultimate shear strength is Tut = 320 N/mm². The initial calculation for the dead load resulted in 1125 kN, but was identified as incorrect due to the use of an improper formula for bending stress. Participants emphasized the importance of using correct unit symbols, such as MPa for N/mm² and kN for kiloNewton.
  • Understanding of structural engineering principles
  • Familiarity with bending stress and shear strength calculations
  • Knowledge of unit symbols in engineering (e.g., MPa, kN)
  • Basic proficiency in using formulas related to moment of inertia and bending moments
  • Review the correct formula for bending stress in structural beams
  • Learn about the moment of inertia (I) and its significance in beam calculations
  • Study the relationship between bending moment (M), shear force (V), and load (P)
  • Explore the concepts of elastic modulus (E) and radius of gyration (R) in beam theory
Structural engineers, civil engineering students, and professionals involved in designing and analyzing steel structures will benefit from this discussion.
1884ram
A mild steel beam has a solid square cross section of 100mm and is simply supported by two supports 3m apart. calculate the dead load that can be safely supported when applied to the middle of the beam?
given data:
Ultimate strength in bending is σb = 450N/mm2
Ultimate shear in strength = Tut 320 N/mm2
The maximum bending moment is under the load
So from the bending formula
Bending stress (σb) = P / A
A = Area of cross section
Dead load P = σbA / 4
= 450 x 1002 / 4
= 1125000N (1125KN)
Can anyone confirm that this is the correct answer.
Thanks in advance
1884ram: That currently looks incorrect. It looks like you have the wrong formula for bending stress. Find the correct formula for bending stress, and keep trying.
By the way, N/mm^2 is called MPa. Use the correct unit symbol, MPa. Also, the unit symbol for kiloNewton is spelled kN, not KN. Always use the correct capitalization. Also, always leave a space between a numeric value and its following unit symbol. E.g., 3 m, not 3m.
Thanks for your reply and advice nvn.
I have looked into some other equations and i have found the following:
M / I = σb / y = E / R
(PL / 2) / a4 / 12 = σb / y
Are these correct?
I have tried to use these formulas to calculate dead load but not sure what the E and R values are:
M = 480 x 166 666 / 4 = 1 999 992 0 / 1000 = 1 999 9.92 N m
I = 1 / 12 x 100^4 = 8 333 300 mm^4
σb = 450 mpa
y = 1 / 2 x 100 = 50 mm
E =
R =
L = 100
  • · Replies 22 ·
  • · Replies 33 ·
24K
  • · Replies 17 ·
15K
