Proving Finite Solutions of phi(x)=n for Fixed Integer n
  • Context: Graduate
  • Thread starter Thread starter b0mb0nika
    Finite Integer
The discussion focuses on proving that the equation φ(x) = n, where n is a fixed integer, has a finite number of solutions. The participants analyzed two cases: when x is even and when x is odd. They established that for even x, φ(2x) > φ(x), confirming a finite number of solutions. Additionally, they utilized the inequality φ(x) ≥ √x (valid for x ≠ 2 or 6) and the multiplicative property of the Euler's totient function φ to demonstrate that there are finitely many integers x satisfying φ(x) ≤ n.
  • Understanding of Euler's totient function φ(x)
  • Knowledge of multiplicative functions in number theory
  • Familiarity with inequalities and bounds in mathematical proofs
  • Basic concepts of prime numbers and their properties
  • Study the properties of Euler's totient function φ, including its multiplicative nature
  • Explore the implications of the inequality φ(x) ≥ √x in number theory
  • Investigate the distribution of prime numbers and their role in φ(x)
  • Learn about advanced techniques in mathematical proofs, particularly in finite solution proofs
Mathematicians, number theorists, and students interested in the properties of the Euler's totient function and finite solution proofs in number theory.
b0mb0nika
for n- fixed integer prove that
phi(x)=n has a finite number of solutions
I looked at 2 cases when x is even and when x is odd
1) if x is even then phi(2x)>phi(x) and I showed why it has a finite number of solutions
2) I'm not sure how to show for the case when x is odd.. any ideas?
You don't need to split into even/odd. Have you seen the inequality [tex]\phi(x)\geq \sqrt{x}[/tex]? (valid if x is not 2 or 6). This isn't too difficult to show and gives a bound on the number of x's for a given n. Though if you have the even case already, you could prove the above inequality is always true for odd x.
You could also use the fact that phi is multiplicative. Show that there are a finite number of primes p that will satisfy [tex]\phi(p)\leq n[/tex]. For each of these primes there is a finite number of exponents k that will satisfy [tex]\phi(p^k)\leq n[/tex]. Conclude there are finitely many x with [tex]\phi(x)\leq n[/tex].
i think i got it.. i proved it using the fact that it's multiplicative thanks :smile:
  • · Replies 26 ·
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 0 ·
