Problem concerning square roots
  • Thread starter Thread starter Remos
    Roots Square
The discussion revolves around a mathematical equation involving square roots: x + square(5x + 10) - 8 = 0. Participants are exploring the implications of square roots and their values, particularly in relation to the original poster's assertion about potential solutions.
  • Conceptual clarification, Assumption checking, Mixed
  • The original poster attempts to validate their solutions for x, questioning the teacher's assertion regarding the impossibility of negative square roots. Some participants seek clarification on the interpretation of "square" as square root versus squaring an expression. Others discuss the definition of square roots and their principal values, raising questions about the nature of square roots in mathematical contexts.
The conversation is ongoing, with participants providing insights into the definition of square roots and discussing the distinction between principal square roots and the concept of square roots having both positive and negative values. There is a recognition of differing interpretations, but no explicit consensus has been reached.
Participants note the importance of definitions in mathematics, particularly regarding the principal square root and its implications in problem-solving. The original poster's confusion stems from a misunderstanding of how square roots are defined in the context of their assignment.
Remos
I had this assignment in math class and it doesn't just add up.
Nothing too difficult to solve.
And the answer is:
x1 = 18 if square(5 * 18 + 10) = -10
x2 = 3 if square(5 * 3 + 10) = 5
But teacher says that x1 is not correct. To me it is not logical.
18 + square(5 * 18 + 10) - 8 = 18 + square(100) - 8 =
= 18 + 10 - 8 = 20 <- it doesn't fit into the equation
= 18 - 10 -8 = 0 <- it fits into the equation
I find it logical but teacher says that only positive numbers can come from the square(...).
How so?
10 * 10 = 100
and
-10 * -10 = 100
so
square from 100 is
and
-10.
Where's the catch?
Am I missing something?
"x+ square(5x + 10) - 8 = 0"
is it square root or
x+(5x+10)^2-8=0 ?
x+(5x+10)^2-8=0 ?
By square(...) I meant that -> square root from (...)
By definition, √(a) or sqrt(a) is never negative, so [itex]\sqrt{5x+10}[/itex] can not be -10.
ehild
And the answer is:
It's a good thing you have "square root" in the title, or I wouldn't have been able to understand what you are doing here. I had to mentally translate "square" into "square root" to make sense of what you're doing.
What you have above is incorrect.
If x = 18, then
[itex]18 + \sqrt{90 + 10} = 18 + 10 = 28 \neq 8[/itex]
The square root of a nonnegative real number is always a nonnegative real number. The expression [itex]\sqrt{100}[/itex] has one value, 10. It is NOT also equal to -10.
How so?
10 * 10 = 100
and
-10 * -10 = 100
so
square from 100 is
and
-10.
No. The square root of 100 is 10. Period.
Remos said:
Where's the catch?
Ok, but what do I have to take square root from to get -10?
[itex]-\sqrt{100} = -10[/itex]
Mark44 said:
The square root of a nonnegative real number is always a nonnegative real number. The expression [itex]\sqrt{100}[/itex] has one value, 10. It is NOT also equal to -10. The square root of 100 is 10. Period.
I understand that when dealing with physical measurement problems it usually does not make sense to keep a negative value. Correct me (and all my professors) wrong, but through several calculus courses that I have taken, we have always considered two values when taking the square root of any nonnegative real number, even if we end up throwing one out.
I do not have master's degree or anything, I am just a student, but I find it hard to take the above statement seriously after having found so many instances of the opposite case fascinating and logical.
Your apparent authority on the subject has confused me, so I did a little research in my textbooks.. As I expected, every positive number x has two square roots: [itex]\sqrt{x}[/itex] which is positive, and [itex]-\sqrt{x}[/itex] which is negative... right? Collectively they are referred to as [itex]\pm\sqrt{x}[/itex] I think this is what Remos is alluding to...
It's true that every positive real number has two square roots, one positive and one negative, and that might be where you are confused.
An expression such as [itex]\sqrt{9}[/itex] represents the principal square root, and has a single value, 3. The principal square root of a positive number is positive.
Right.
Right.
Here's from the wikipedia page for Square Root - http://en.wikipedia.org/wiki/Square_root
Every non-negative real number x has a unique non-negative square root, called the principal square root, denoted by a radical sign as [itex]\sqrt{x}[/itex]. For positive x, the principal square root can also be written in exponent notation, as x1/2. For example, the principal square root of 9 is 3, denoted [itex]\sqrt{9}[/itex], because 32 = 3 × 3 = 9 and 3 is non-negative. Although the principal square root of a positive number is only one of its two square roots, the designation "the square root" is often used to refer to the principal square root.
I have tossed these sentences against each other for a few minutes and I think I've figured out the semantics. So, every positive real number can have two square roots, but performing the square root operation can only result in the principal root of the number?
I think it's all coming together, especially after reading the wiki.
Thanks!
Sorry to steal your thread Remos, but I hope maybe our discussion has clarified your question a little bit?
Thanks!
Right, that's exactly it. Similarly, every real number has three cube roots, but performing the cube root operation results in the principal cube root. Same with fourth roots, fifth roots, etc.
I hope so. This was one of the things that he/she was unclear on.
  • · Replies 68 ·
13K
