Using Characteristic equations to solve 2nd order linear DEQ's
The discussion focuses on solving the initial value problem represented by the second-order linear differential equation: cos(t/3)y'' + (6t^2)y' + ((t-5)^-3)y = 0. The characteristic equation derived is r^2 + [(6t^2)/(cos(t/3))]r + [(t-5)^-3]/(cos(t/3)). The user expresses confusion regarding the quadratic equation's roots, which are dependent on the variable t rather than being constant. Ultimately, the solution requires identifying the interval of validity, determined by the singularity at t=5 and continuity of other terms, resulting in the interval [1,5).
  • Understanding of second-order linear differential equations
  • Familiarity with characteristic equations and their derivation
  • Knowledge of quadratic equations and their solutions
  • Concept of continuity and singularities in mathematical functions
  • Study the derivation and application of characteristic equations in differential equations
  • Learn how to solve quadratic equations with variable coefficients
  • Explore the concept of singularities and their impact on solution intervals
  • Investigate the continuity of functions and its relevance in differential equations
Mathematics students, educators, and professionals dealing with differential equations, particularly those focusing on second-order linear DEQs and their solutions.
Tricky557
The problem statement:
Find the largest interval in which the solution of the following initial value problem is valid:
cos(t/3)y'' +(6t^2)y' + ((t-5)^-3)y = 0
Initial conditions:
y(1) = 1
y'(1)= 3
I have a few questions concerning this problem.
I've converted it to it's characteristic equation:
r^2 + [(6t^2)/(cos(t/3)]r + [(t-5)^-3]/(cos(t/3))
This isn't something I'm readily able to factor. So I move to the quadratic equation... Which is what I'm confused about.
When I write down the quadratic equation for this problem, I have a feeling that I've gone down the wrong path to the solution because it turns out to be something that I don't really know what to do with. I can get 2 different and unique roots, but they're both going to be in terms of t. Every example I've seen of this being done always ends with the 2 r's as numbers. Never in terms of t.
I'm not sure what to do here.
Do I even need to solve this equation? I've been thinking about it and all it asks is for the interval where the solutions will be valid, and I can do that relatively easily. All I would need to do, if that were the case for this problem, is to solve these few equations:
cos(t/3) = 0
t-5 = 0
Wherever these equations are true are where the interval boundaries are going to be.
A long post.. almost a wall of text, any help would be greatly appreciated.
Since (t-5)^-3 has a singularity at t=5 & other terms are continuous,the answer is [1,5).
  • · Replies 17 ·
