Magnitude of the maximum acceleration spring problem
The discussion centers on a physics problem involving a 29.0 kg block undergoing simple harmonic motion (SHM) on a frictionless air track, connected to a spring. The block is initially displaced to 0.350 m and has a period of 5.30 s. To find the position of the mass after 4.293 s, the angular frequency (ω) can be calculated using the formula ω = 2π/T. The maximum acceleration of the mass is determined using the formula a = Aω², where A is the amplitude of 0.350 m.
  • Understanding of simple harmonic motion (SHM)
  • Knowledge of angular frequency (ω) and its calculation
  • Familiarity with the relationship between force, mass, and acceleration
  • Ability to apply formulas for maximum acceleration in SHM
  • Calculate angular frequency (ω) using the formula ω = 2π/T
  • Determine the position of the mass at t = 4.293 s using x = A cos(ωt)
  • Explore the derivation of maximum acceleration in SHM using a = Aω²
  • Investigate the impact of varying mass and spring constant on SHM characteristics
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for examples of simple harmonic motion problems.
SnowOwl18
Stuck!
---A 29.0kg block at rest on a horizontal frictionless air track is connected to the wall via a spring. The equilibrium position of the mass is defined to be at x=0. Somebody pushes the mass to the position x= 0.350m, then let's go. The mass undergoes simple harmonic motion with a period of 5.30s. What is the position of the mass 4.293s after the mass is released?
Consider the same mass and spring discussed in the previous problem. What is the magnitude of the maximum acceleration the mass undergoes during its motion? --------------
Um so...what I tried to do for the first part was find the x postion using the equation x=Acos(wt)...but then I realized I don't have enough information. I know for the second part that Max acceleration is a= Aw^2 ...soo anyway, in the first question I think A = 0.35m...and w= k/m --> ?/29kg ... and t= 4.293s...so basically I'm lost and I'd be very thankful for help. Hope some of that made sense! Thanks :)
[tex]\omega = \frac{2*\pi}{T}[/tex]
T is the time period.
So, you can directly calculate [tex]\omega[/tex]
spacetime
www.geocities.com/physics_all
SnowOwl18 said:
Stuck!
Use the equation of shm to determine the k of the spring (ie. [itex]\omega = \sqrt{k/m}[/itex]). Of course, maximum acceleration is the point of maximum force. Since F = -kx, this is at the point or maximum displacement, which is the amplitude.
AM
  • · Replies 26 ·
  • · Replies 22 ·
