Domain / range of this function
The discussion revolves around determining the domain and range of the function f(x) = sqrt(4 - x^2). Participants also mention symmetry in relation to the function.
  • The original poster attempts to identify the domain by solving the inequality 4 - x^2 >= 0. They express uncertainty about how to mathematically show the range. Some participants suggest using the relationship between x and y in the function to derive inequalities for y.
Participants are exploring different methods to determine the domain and range. Some guidance has been provided regarding the implications of the square root function and the necessity of considering non-negative values for y. There is an ongoing examination of the function's behavior over a specified interval.
There is a mention of needing to consider the closed range [-2, 2] for the function, which may influence the determination of the range. Participants are also discussing the implications of squaring equations and the potential for extraneous solutions.
zeion
I don't remember the exact question right now, but it was something like this:
I needed to give the domain / range of it, and also symmetry I believe.
I know this is a half circle after being graphed, but how can I show the domain and range in a math way?
For domain, I know 4 - x^ must >= 0, so I can solve for it that way.
But what about range?
Can I also just isolate x and then get sqrt with y inside and restrict to real numbers?
Formally, you should say: if "y" is an element in the domains, then there's an x, so that:
[itex]\sqrt{4 - x^{2}}= y[/itex]
That already means that y [itex]\geq[/itex] 0, since the square root always gives non-negative values.
Squaring the equation:
x2 = 4 - y2
This equation only has a solution if the right side is positive (or zero). therefore:
4 - y2 [itex]\geq[/itex] 0
Check out what inequality you get from that.
Of course you need to combine it with y [itex]\geq[/itex] 0 (squaring equations usually leads to extra solutions) with the inequality you got.
A little less formally, but probably valid - you could use the graph of the function. By finding the absolute maximum and minimum of the function in it's closed range [-2,2] and noting that the function gets any values between them, being continuous in that segment - you can find your range.
[tex]\sqrt4 = \pm 2[/tex]
The square root function is defined to be the positive root of a number, unlike the operation of taking a root from a number.
  • · Replies 23 ·
  • · Replies 22 ·
