Optic axis of a calcite crystal
  • Context: High School
  • Thread starter Thread starter prashant07
    Axis Crystal Optic
The optic axis of a calcite crystal is the specific direction within the crystal where mixed-polarization light does not split into two beams. Calcite, a birefringent crystal, exhibits different refractive properties based on light polarization due to its unique atomic structure. When light enters the optic axis, it experiences uniform atomic spacing, resulting in no double image formation. Understanding this concept is essential for experiments involving polarized light and crystal optics.
  • Birefringence in crystals
  • Polarization of light
  • Atomic structure of calcite
  • Basic principles of optics
  • Explore the properties of birefringent materials
  • Learn about polarized light sources, such as lasers
  • Investigate the principle plane and principle axis of crystals
  • Conduct experiments with calcite to observe double images
Students, educators, and researchers in optics, materials science, and crystallography will benefit from this discussion, particularly those interested in the behavior of light in birefringent materials like calcite.
prashant07
What is an optic axis of a calcite crystal ?
Science news on Phys.org
Calcite is a birefringent crystal, meaning that light that strikes and goes through the crystal will refract differently depending on its polarization. This is because the crystal's atomic structure is different in one direction than in another direction. If you shine a light with mixed polarization through such a crystal (such as sunlight bouncing off of a pencil tip), then the two different polarizations in the light will respond differently to the crystal. One polarization will bend more than the other, so that out the other side you will get two beams of light appearing at different places (e.g. leading to two images of a pencil tip when you look at it through the crystal. If you send in polarized light (like from a laser), it will not split because it can only refract in one way.
The optic axis is the direction in the crystal where if you shine the mixed-polarization light in at this direction, it will not split into two beams. In this direction, the atomic structure looks the same in both directions.
As an oversimplified picture, consider the atomic lattice to be a simple rectangular grid with the atoms closer in one dimension than the other:
A beam of light going into the screen will see a difference in this structure from side-to-side versus up and down. the part of the beam with the electric field up and down with react differently than the part of the beam with electric field going side-to-side in this picture. If instead, the light beam came from the right and headed left across the screen an encountered this lattice, and if the atoms where spaced into the screen with the same spacing as they are up and down, then the beam would see a uniform grid. This would be the optic axis.
You can get a piece of calcite inexpensively at most science museum gift shops or mineral stores, and then do quick experiments orienting it different ways and looking at how the double image is affected to get a feel for this.
thanks for the previous reply...
please also explain me the concept of principle plane and principle axis of the crystal.
  • · Replies 43 ·
