Hydraulic or pneumatic for applying loads ranging between 500-1000lb
The discussion focuses on the selection between hydraulic and pneumatic systems for a load application device designed to apply forces between 500-1000 pounds in three directions. Users recommend hydraulic systems due to their superior response times compared to pneumatic systems, which can experience pressure drops due to the compressibility of air. The user seeks compact components, including miniature compressors, valves, switches, and linear actuators with rod locks for pneumatic applications.
  • Understanding of hydraulic systems and their components
  • Familiarity with pneumatic systems and their characteristics
  • Knowledge of load application techniques and requirements
  • Experience with miniature actuators and control systems
  • Research hydraulic system design principles and components
  • Explore pneumatic system limitations and performance characteristics
  • Investigate miniature linear actuators suitable for load applications
  • Learn about pressure management in hydraulic and pneumatic systems
Mechanical engineers, design students, and anyone involved in developing load application systems using hydraulic or pneumatic technologies.
koab1mjr
Hi all
I am finally at senior design and I am looking to use hydraulics or pneumonics to be the driver of my load application system. I have zero experience with either so need some guidance.
The intention is to have a testing device which can apply loads around 500 -1000 pounds. in three directions. I was looking into using pressure as I can have all of them drivin off a single pump.
I have been browsing the interent on the drawbacks of each and I was looking for more advice.
This system has to be small. So i am looking for miniature versions of everything compressor valve switch and linear actuators (with rod locks if using pneumatic).
any thoughts ?
thanks in advance
koab1mjr said:
Hi all
any thoughts ?
thanks in advance
You could technically use either, however, the hydraulic system will have a better response than the air one. Imagine pressuring up with a compressible medium - you'll have a sudden expansion in the cylinder as soon as it moves which will cause the pressure to drop rapidly. With a hydraulic medium this doesn't happen normally.
CS
  • · Replies 19 ·
  • · Replies 21 ·
17K
10K
