Exam in 2 Hours: Solving Kinematics and Tidal Problems for Physics Exam
  • Thread starter Thread starter rei
    Exam
The discussion revolves around two physics problems related to kinematics and tidal motion. The first problem involves a collision between a rod and a small object, focusing on the center of mass and angular velocity. The second problem concerns the tidal changes affecting a harbor and the safe entry of boats based on water depth variations.
  • Mixed
  • Participants explore the calculation of the center of mass and angular velocity for the first problem, with one suggesting the use of weighted averages. For the tidal problem, there is discussion about modeling the water level as a sine wave, with attempts to determine amplitude and vertical shift.
Some guidance has been offered regarding the mathematical approaches to both problems, including the use of sine waves for the tidal problem. However, there are still questions about specific parameters, such as the phase shift in the sine function, indicating that participants are actively seeking clarification.
The original poster expresses urgency due to an impending exam and indicates uncertainty about the problems, which may affect the depth of discussion. There is a focus on hints rather than complete solutions, aligning with the forum's learning-first approach.
rei
These might be really silly problems for a lot of you but I'll have an exam in 2 hours and I still don't know how to do these problem ( which's supposedly the types of questions that will show up in the exam). I'll be really appreciate if someone can help me!
1. An uniform thin rod 80 cm long with mass of 1 kg lies on a frictionless horizontal surface. A second small object of mass 1 kg strikes the rod 20 cm long from one end traveling with a velocity of 10m/s directly perpendicular to the length of the rod. the small object stick to the road after the collision. Compute ( after the collision):
a, the velocity of the center of mass of the system composed of the rod and the object .
b, angular velocity of the system about the center of mass.
2. An ancient military harbor was protected by underwater reef that was 12ft out of the water at low tide and 4 ft under water at high tide. Friendly boats could enter the harbor as long as there was 3 ft of water above the reef. The depth of the water produced by the tides oscillates as if the water level were undergoing simple harmonic motion between high tide and low tide with a period of 12.5 hours. What was the duration of each time interval during which ships could safely enter the harbor.
is there any hint? Thanks a lot!
a. The velocity of the center of mass is equal to the weighted average of the mass*velocity of each object.
b. [tex]L = r \times p = I\omega[/tex]
2. Convert all that information into a sine wave. You can start by determining the amplitude and vertical shift. The period shouldn't be too hard to incorporate in.
I still don't understand. we have:
x= 8 cos (omega t + phi)
omega = 2pi/T
but how can I find phi?
[tex]x = 8cos(\omega t + \phi)[/tex]
All phi does is shift the graph [tex]-\phi[/tex] on the x axis. Just let it equal 0. Also, be careful to add in the vertical shift.
  • · Replies 26 ·
14K
