Calculation of equilibrium using fugacities
The discussion centers on the calculation of equilibrium using fugacities in vapor-liquid systems. The formula "(fL/fv)-1" is utilized to determine equilibrium, where fL represents the fugacity of the liquid and fv represents the fugacity of the vapor. When this calculation approaches zero, it indicates that the system has reached chemical equilibrium. The participants seek clarification on why fL is placed in the numerator instead of fv, despite both fugacities being equal at equilibrium.
  • Understanding of thermodynamics principles, specifically fugacity.
  • Familiarity with vapor-liquid equilibrium concepts.
  • Knowledge of equilibrium calculations in chemical systems.
  • Basic proficiency in mathematical algorithms for equilibrium analysis.
  • Research the derivation and significance of the fugacity coefficient in thermodynamics.
  • Explore the application of the Gibbs phase rule in vapor-liquid systems.
  • Learn about the role of pressure and temperature in determining fugacity.
  • Investigate advanced algorithms for calculating fugacity in non-ideal mixtures.
Chemical engineers, thermodynamics students, and researchers focused on phase equilibria and fugacity calculations in chemical processes.
Notwen7
Its been a while since I took thermo. I was looking through my notes regarding fugacity at chemical equilibrium. There was a clever algorithm used to determine whether the pure compound was at equilibrium based upon the varying pressure with a constant temperature. It had the calculation "(fL/fv)-1" display values, fL being fugacity of the liquid and fv being the fugacity of the vapor. After several inputs of different pressures this calculation will approach 0. Now if "(fL/fv)-1" equals zero then fugacities are equal yielding a chemical equilibrium.
Now if my memory serves there is a reason why we use "(fL/fv)-1" in lieu of "(fv/fL)-1". I am not sure why fL has to be in the numerator. If someone can assist me or show me the right direction I would greatly appreciate it.
  • · Replies 22 ·
12K
  • · Replies 0 ·
9K
