Electric Dipole - Oppositely charged hemispheres
The problem involves a sphere with a uniform charge density in one hemisphere and an opposite charge density in the other hemisphere, leading to the calculation of the electric potential at large distances. The original poster seeks to determine the function \( g_n(\theta,\phi) \) and the numerical value for \( n \) in the potential expression.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss using Taylor expansions and integrals to derive expressions for gravitational force and electric potential. There is consideration of the dipole approximation and the relevance of far-field formulas.
Participants are exploring various interpretations of the problem, including the implications of the leading order term in the potential and the relationship between electric and gravitational forces. Some guidance has been offered regarding the use of dipole approximations and potential formulas, but no consensus has been reached.
There is mention of the problem being a test question, which may impose constraints on the methods allowed. Participants are also questioning the accuracy of certain approximations in different regions relative to the dipole.
ModusPwnd
A sphere of radius [itex]a[/itex] carries a uniform charge density [itex]\rho_0[/itex] in one hemisphere and the opposite charge density [itex]-\rho_0[/itex] in the other hemisphere. The charged sphere produces an electric potential [itex]\Phi (r,\theta,\phi)[/itex]. For [itex]r>>a[/itex], the potential to leading order is of the form,
[tex] \Phi(r,\theta,\phi) \approx \frac{g_n(\theta,\phi)}{r^n}[/tex]
Find [itex]g_n(\theta,\phi)[/itex] and the numerical value for n.
I presume the multiple expansion could be used, but this was a test question so I think I could do it without having the expansion memorized.
Any ideas?
Thanks!
If you had to get an expression for gravitational force exerted by this body at large distances, except that one-half would consist of "negative" matter, what would you do?
If I wanted the gravitational force, I would set up the integral over the region, taylor expand it and then integrate the leading term. Does that sound right?
Plus, since I need potential and not force, it will be easier since its a scalar.
That sounds good overall. You want to find the c.m., pretend all the charge is there, now you have a standard dipole. Potentials may be the way to go, but I'm not sure. There are probably formulas floating around out there in cyberspace giving the c.m. of a hemisphere ... I would forget about Taylor series expansions. The formula for the field at large distances from a dipole is very standard textbook stuff.
The question clearly asks for the leading order term of the potential though.
I interpreted that to mean the far-field formula. The far-field formula IS a first-order ("leading") approximation. That's why it's called far-field. Does not apply when near the dipole, gets too inaccurate. It's 100% accurate only at infinity.
See http://hyperphysics.phy-astr.gsu.edu/hbase/electric/dipole.html
Look at "dipole moment" part. Not that z has to be >> r, the distance between the spehers' c.m. in your case.
However, I just noticed they want an expression for everywhere around the dipole (albeit at far distances). The formula in the link only givs the field along the line z, perpendicular to r.
This is a bigger deal than I thought. May come back to it, might not be too bad.
Here's the best I've found on your problem:
http://phys.columbia.edu/~nicolis/Dipole_electric_field.pdf
If the last equation is expanded in spherical coordinates, that should be the answer. I would set up the dipole along the z axis, with the origin half-way between the two effective point charges.
