Circular motion of bucket of water
The discussion revolves around the mechanics of swinging a bucket of water in a circular motion and the forces at play that prevent the water from spilling out. Participants explore concepts related to centripetal force, acceleration, and the behavior of objects in circular motion, with some references to analogous situations such as rollercoasters.
  • Some participants propose that the water does not spill because the centripetal force acting on the bucket is greater than the force of gravity acting on the water.
  • Others argue that the acceleration of the bucket can exceed the acceleration due to gravity, preventing the water from falling out.
  • A participant mentions a formula for calculating centripetal force, although they express uncertainty about its correctness.
  • One participant raises a question about the behavior of an object (a piece of wood) in the water when the bucket is swung, suggesting it may remain at the same level as when at rest.
  • Another participant draws an analogy to a rollercoaster to explain why the water stays in the bucket, emphasizing the concept of inertia.
  • One contribution compares the situation to the moon's orbit, suggesting that the water's velocity allows it to deviate from a straight path despite gravitational pull.
  • A later reply introduces an unrelated topic about the period of the moon's motion, indicating a shift in focus from the original discussion.
Participants express various viewpoints on the mechanics of the situation, with no clear consensus reached. Some explanations are contested, and different analogies are used to illustrate similar points, indicating a range of interpretations.
There are unresolved questions regarding the assumptions made about the forces involved and the behavior of objects in the bucket. The discussion includes varying degrees of certainty about the correctness of the proposed explanations and formulas.
alchemist
when a bucket is filled with some water, you take it up and swing it around, if you swing it hard enough, the water in it would not spill out, why is this so?is it because the reaction force from the centre of rotation is acting on the water?
In order to move the bucket out of a straight line, you have to apply force to it (this is the "centripetal" force). If you swing it fast enough, the force you are applying to the bucket (and so the 'reaction force' as you put) will be greater than the force of gravity.
To calculate this force you might need this:
F = m*v^2/r
F = the centripetal force (i don't know if this is a correct word )
m = mass
v = velocity
r = distance
If that didn't quite clarify it enough:
When you swing the bucket in a circle, there is a force pulling toward the center of rotation, which would probably be at your shoulder. When the bucket is above your head, that force is pulling downward. If you are swinging fastly enough, the force generates acceleration that is greater thant the acceleration due to gravity. So the water cannot escape from the bucket due to gravity, because the bucket is accelerating downward faster than gravity is causing the water to. It's like trying to run away from an olypmic runner. Basically, as long as the water and bucket are putting a substantial amount of pressure on each other, the water won't fall out of the bucket.
Another way to explain it: When the bucket is at the top of the rotation facing downward, the water is accelerating down out of the bucket. But your force exherted on the string is accelerating the bucket down FASTER than the water can accelerate out of the bucket. So the water stays in the bucket.
I just wonder...
In the bucket you are swinging around you put a piece of wood,
if the bucket is above your head, will the wood be at the same level
in the water as it was in rest ?
this question was asked during a science quiz here in Holland.
Really nobody knew the answer, nor had any idea, maybe one of you?
Ton
I would think the block would stay at the same level. The change in acceleration would be analogous to changing the acceleration due to gravity.
The reason why the water does not leave the bucket is because the water is wanting to travel in a straight line but is being forced to turn with the bucket because it has no where else to go. Just like when you are on a rollercoaster and doing a loop. Say you are traveling, with a ball in your hand, in a straight line going pretty fast and were about to do a loop and just before you went up to start the loop you let go of the ball. The ball would keep going in a straight line as you were turning up and it would seem as if the ball fell to your feet. This is why...
The water doesn't fall because of the same reason that the moon doesn't fall to the earth. Even though it is being pulled by it.
Due to the velocity that it has, at every point in its motion, it deviates from the path of falling, and due to the force of gravity, from following a tangential path.
And what keeps the bucket from flying off is your hold on it.
spacetime
www.geocities.com/physics_all/index.html
The definitive accommodation of your question can be answered in a recording by Dr. F. Zappa where he not only describes centripetal motion and it's local effects , but also is the first noted mention of string theory, The essay is entitled ," Moving to Montana soon".
The man died rather young after contracting probate cancer by exposure to Tipper Gore,
Hi..my question is on finding the period for the moon's motion around the earth. I need to express my answer in days and compare it to the length of a month. The moon orbits the Earth at a distance of 3.85 X 10^8m. The mass of the Earth is
5.98 X 10^24 kg. I know that I am supposed to use the formula T=2 Pi (r^3/2) / square root of GMe, and then when I get my answer for that I divide by 86400 to express my answer in days. I think my answer should be somewhere around 27.153 days, but I am not getting anything close to that. I have worked and worked the problem out and I just cannot solve it. I think I may be using my calculator incorrectly. I am coming up with an answer of 2.68^11 and then when I divide that by 86400 I get 3101851.852, which is very wrong. Please help!
  • · Replies 35 ·
  • · Replies 37 ·
