New Reply
maximum velocity at the lowest point
Share Thread
Sep26-11, 06:12 AM   #1
Say that there is a car on a top of the hill and it was on a frictionless surface, explain why the maximum speed of the car would occur at the lowest point of the hill?
In this case would you prove it through the conservstion of energy PE + KE = PE + KE?
If so, how does this prove that Vmax occurs at the lowest point?
Any help would be great, Thanks :)
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Sep26-11, 07:54 AM   #2
What can you say about PE at the top vs at the bottom? Which is higher?
Sep27-11, 02:47 AM   #3
Assume that there is no PE at the top of the hill...
What do you mean which is higher?
Sep27-11, 03:06 AM   #4
Quote by helpinghand View Post
PE is a relative phenomenon. U cant say that there is no PE at the top.
if there is no PE at the top......PE at the bottom should be negative
Sep27-11, 03:11 AM   #5
Quote by viplav View Post
Oops... typo, PE = mgh and KE = 0
Sep27-11, 03:15 AM   #6
hi friend
Assume that height of the hill is 'h' m.
now initially as the car is rest on the top of the hill.......KE is zero and PE is 'mgh'
when the car is at the bottom of the hill the total PE at the top should be KE at the bottom........since PE at the bottom is zero
At any point in between top and bottom....the total energy is the sum of both PE and KE.....but at the bottom the total energy is only KE so v is max at this point
New Reply
Similar discussions for: maximum velocity at the lowest point
Thread Forum Replies
speed of a pendulum at its lowest point Introductory Physics Homework 2
Ball hanging from string, what is tension when at its lowest point? Introductory Physics Homework 3
lowest frequency that produces an interference maximum Introductory Physics Homework 2
[SOLVED] Pendulum - Kinetic Energy at Lowest Point? Introductory Physics Homework 2
Tension of string of pendulum at lowest point Introductory Physics Homework 3
