Expand & Sum Binomial Series: f(x)= x+x^2
  • Thread starter Thread starter DivGradCurl
    Binomial Series
The discussion revolves around expanding the function f(x) = (x + x^2) / (1 - x)^3 as a power series and using this expansion to find the sum of the series Σ(n^2 / 2^n). Participants are exploring binomial series and power series expansions within the context of calculus.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss various methods for expanding f(x) and question the correctness of certain steps in the expansion process. Some express confusion about the relationship between the series and the function f(x), while others suggest different approaches to rewriting the series.
The discussion is active, with participants providing corrections and clarifications on previous posts. Some have made progress in developing their solutions, while others are still grappling with specific transitions in their reasoning. There is a recognition of the need for clearer connections between the function and the series sum.
Participants are working under the constraints of homework guidelines, which may limit the use of certain methods or require specific forms of answers. There are also indications of unclear areas in the problem-solving process that are still being addressed.
DivGradCurl
(a) Expand
[tex]f(x)=\frac{x+x^2}{\left( 1-x\right) ^3}[/tex]
as a power series.
(b) Use part (a) to find the sum of the series
[tex]\sum _{n=0} ^{\infty} \frac{n^2}{2^n}[/tex]
[tex]\hline[/tex]
Here is what I've got:
(a)
[tex]f(x)=\frac{x+x^2}{\left( 1-x \right) ^3 } = \left( x + x^2 \right) \left[ 1 + (-x) \right] ^{-3} = \left( x + x^2 \right) \sum _{n=0} ^{\infty} \binom{-3}{k} (-x) ^k = \left( x + x^2 \right) \sum _{n=0} ^{\infty} (-1) ^k \binom{-3}{k} x ^k[/tex]
[tex]f(x) = \left( x + x^2 \right) \left[ \binom{-3}{0} - \binom{-3}{1}x + \binom{-3}{2} x^2 - \binom{-3}{3} x^3 + \binom{-3}{4} x^4 - \cdots \right][/tex]
[tex]f(x) = \left( x + x^2 \right) \left[ 1 - \frac{(-3)}{1!}x + \frac{(-3)(-4)}{2!}x^2 - \frac{(-3)(-4)(-5)}{3!}x^3 + \frac{(-3)(-4)(-5)(-6)}{4!}x^4 -\cdots \right][/tex]
[tex]f(x) = \left( x + x^2 \right) \left[ 1 + \frac{1}{2} \sum _{n=1} ^{\infty} \frac{\left( n+2 \right)!}{n!}x^n \right] = \left( x + x^2 \right) \left[ 1 + \frac{1}{2} \sum _{n=1} ^{\infty} (n+2)(n+1)x^n \right][/tex]
[tex]f(x) = x + x^2 + \frac{1}{2} \sum _{n=1} ^{\infty} \left[ (n+2)(n+1)x^{n+1} \right] + \frac{1}{2} \sum _{n=1} ^{\infty} \left[ (n+2)(n+1)x^{n+2} \right][/tex]
(b)
[tex]\sum _{n=0} ^{\infty} \frac{n^2}{2^n} = ?[/tex]
Thank you
Did you write the question correctly? I don't see how you can use partial fractions in the last equation you give to get the question again. I don't think you can either because for x = 2 the equivalency isn't there.
thiago_j said:
(a) Expand
[tex]f(x)=\frac{x+x^2}{\left( 1-x^3\right)}[/tex]
as a power series.
[tex]\hline[/tex]
(a)
[tex]f(x)=\frac{x+x^2}{\left( 1-x^3\right)} = \left( x + x^2 \right) \left[ 1 + (-x) \right] ^{-3}[/tex]
That last equality is incorrect!
I see. You guys are right about that last equality.
If I have
I may need to rewrite
[tex]\frac{n^2}{2^n}[/tex]
and compute it with the aid of the f(x) I found in part (a). What I can do is:
[tex]\frac{n^2}{2^n} = n^2 \left( \frac{1}{2} \right) ^n[/tex]
but the connection with f(x) still is not clear.
I've just made some corrections to my 1st post... did I get it right this time?
Thanks.
vsage,
I'm sorry. I wrote it incorrectly last time. It isn't:
[tex]\frac {x^2+x}{1-x^3}[/tex]
I've just edited my 1st post to fix it. Here it is:
Sorry again, and thanks for your help. :smile:
Consider that [tex]\frac {1}{(1-x)^3} = \frac {d^2\frac{1}{2} \frac{1}{1-x}}{dx^2}[/tex]
Well, I see that:
[tex]f(x) = \frac{x+x^2}{\left( 1-x\right) ^3} = -\frac{1}{2}\left( x + x^2 \right) \frac{d^2}{dx^2} \left[ \frac{1}{1-x} \right] = -\frac{1}{2}\left( x + x^2 \right) \frac{d^2}{dx^2} \left[ \sum _{n=0} ^{\infty} x^n \right] = -\frac{1}{2}\left( x + x^2 \right) \sum _{n=2} ^{\infty} n(n-1)x^{n-2}[/tex]
This method is, in fact, simpler. The directions of this problem in part (a) are to expand f(x) as a power series, so it's ok to do that. But, I've got this exercise from the "Binomial Series" section in my calc book, so I tried to stick to it. That's why I used it in my 1st post.
Maybe your tip was about the connection between f(x) and the series in part (b). To be honest, I don't see how it may be related to it.
Folks, let me rephrase what I have. I was able to develop the solution quite a bit farther, but there still are some unclear areas.
Problem:
(a) Expand
as a power series.
[tex]\sum _{n=1} ^{\infty} \frac{n^2}{2^n}[/tex]
[tex]\hline[/tex]
Solution:
(a)
[tex]f(x)=\frac{x+x^2}{\left( 1-x\right) ^3} = \left( x + x^2 \right) \left[ 1 + (-x) \right] ^{-3} = \left( x + x^2 \right) \sum _{n=0} ^{\infty} \binom{-3}{k} (-x) ^k = \left( x + x^2 \right) \sum _{n=0} ^{\infty} (-1) ^k \binom{-3}{k} x ^k[/tex]
[tex]f(x) = x + x^2 - \frac{x\left( 3x-3x^2+x^3\right)}{\left( x-1 \right) ^3} - \frac{x^2\left( 3x-3x^2+x^3\right)}{\left( x-1 \right) ^3} \qquad \fbox{UNCLEAR 1}[/tex]
[tex]f(x) = x + x^2 - \left[ x +\frac{1}{\left( x-1 \right) ^2} +\frac{1}{\left( x-1 \right) ^3} \right] - \left[ x^2 + \frac{1}{ x-1} + \frac{2}{\left( x-1 \right) ^2} + \frac{1}{\left( x-1 \right) ^3} \right][/tex]
[tex]f(x) = -\frac{1}{ x-1} -\frac{3}{\left( x-1 \right) ^2} - \frac{2}{\left( x-1 \right) ^3}[/tex]
(b)
[tex]\sum _{n=1} ^{\infty} \frac{n^2}{2^n} = 6 = f\left( \frac{1}{2} \right) \qquad \fbox{UNCLEAR 2}[/tex]
Comments:
[tex]\fbox{UNCLEAR 1}:[/tex] I don't understand the transition from the series above to this result.
[tex]\fbox{UNCLEAR 2}:[/tex] I've found the sum of the series ("6") with the aid of my calculator. Later, I evaluated a guess ("1/2"), which gave the correct answer. However, it still isn't explicit the connection between
[tex]\sum _{n=1} ^{\infty} \frac{n^2}{2^n} \qquad \mbox{ and } \qquad f(x) = \frac{x+x^2}{\left( 1-x\right) ^3}[/tex]
Thank you very much.
Guys, I may have found the rest of the solution:
(a)
[tex]f(x)=\frac{x+x^2}{\left( 1-x\right) ^3} = \left( x + x^2 \right) \left[ 1 + (-x) \right] ^{-3} = \left( x + x^2 \right) \sum _{n=0} ^{\infty} \binom{-3}{n} (-x) ^n = \left( x + x^2 \right) \sum _{n=0} ^{\infty} (-1) ^n \binom{-3}{n} x ^n[/tex]
[tex]f(x) = x + x^2 - \frac{x\left( 3x-3x^2+x^3\right)}{\left( x-1 \right) ^3} - \frac{x^2\left( 3x-3x^2+x^3\right)}{\left( x-1 \right) ^3} \qquad \fbox{UNCLEAR}[/tex]
[tex]f(x) = -\frac{1}{ x-1} -\frac{3}{\left( x-1 \right) ^2} - \frac{2}{\left( x-1 \right) ^3} = \frac{x\left( x+1 \right)}{\left( x-1 \right) ^3} = x \frac{d}{dx} x \frac{d}{dx} \left[ \frac{1}{1-x} \right] = x \frac{d}{dx} x \frac{d}{dx} \left[ \sum _{n=0} ^{\infty} x^n \right][/tex]
[tex]f(x) = \sum _{n=1} ^{\infty} n^2 x^n[/tex]
(b)
[tex]\sum _{n=1} ^{\infty} \frac{n^2}{2^n} = \sum _{n=1} ^{\infty} n^2 \left( \frac{1}{2} \right) ^n = f\left( \frac{1}{2} \right) = \frac{\frac{1}{2}+\left( \frac{1}{2} \right)^2}{\left( 1-\frac{1}{2}\right) ^3} = 6[/tex]
Comments:
[tex]\fbox{UNCLEAR}:[/tex] I don't understand the transition from the series above to this result.
  • · Replies 21 ·
