Calculate Exact Area b/w x-axis & Graph of y=7-8x+x^2
  • Thread starter Thread starter mugzieee
    Integrals
The problem involves calculating the exact area between the x-axis and the graph of the quadratic function y = 7 - 8x + x². Participants are exploring methods to find this area, including the use of the Fundamental Theorem of Calculus and definite integrals.
  • Mixed
  • Participants discuss the application of the Fundamental Theorem of Calculus and question the relevance of specific values used in their calculations. There is confusion about the correct interval for integration and the significance of points where the function intersects the x-axis.
Some participants have provided guidance on factoring the quadratic equation and suggested using definite integrals to find the area. However, there remains uncertainty about the correct approach and the interpretation of the problem, with no clear consensus reached.
There is mention of the need to consider areas above and below the x-axis, as well as the importance of selecting appropriate limits for integration based on where the function equals zero.
mugzieee
im given a problem that gives me y=7-8x+x^(2) and it says calculate the exact area between the x-axis and the graph of y.
What i have done is tried using the fundamental theorom, by saying that F(b)=2600, and F(a)=2600. I got these values by graphing and looking at where the y graph starts and stops. but when i use the fundamental theorom i get a bogus answer. The answer given in the book is 36, can any1 point me in the correct direction please?
do you have to use the fundamental theorem? I'm not sure where you got F(b) and F(a) from really also. Where did the 2600 come from again? I don't see how it's relevant to where the curve crosses the x axis. Integrating from where f(b) = f(a) = 0 for distinct a and b should work but I'm not sure if you're allowed to do it that way.
yes i have to use the theorom, F(b) and F(a) i got from looking at the graph of y, and just taking the starting point, and the ending point of the graph, as in the interval its in. so what i did was just take the total area
from [-2600,2600]. i have no idea what the distinct a and distinct be method is sorry.
The integral of f(x)dx from a to b is F(b) - F(a). That's the first fundamental theorem right? What's F(t)? It's the integral from 0 to t of f(x)dx. So F(b) - F(a) = integral from 0 to b of f(x)dx - integral from 0 to a of f(x)dx. You can't just take the area from an arbitrarily large value of x on the function because any area that is below the x-axis gets subtracted from the area above the x axis. This is why you should choose your b and a more carefully - the two places where f(x) = 0.
You're making this way too complicated.
Take your equation Y = x^2 - 8x + 7 and factor it to get y=(x-7)(x-1), and solve this for the points where y = 0.
so you have x=1, 7.
Take this, and do a definite integral of that equation:
Integral(1 to 7) (x^2 - 8x + 7)dx
so you get: ((x^3)/3 -4x^2 + 7x)|(1 to 7)
Plug in your numbers: (7^3)/3 - 4(7^2) + 7(7) - (1^3)/3 + 4(1^2) - 7
simplify to get: -36
since area is always positive, your area is 36.
thanx cam, appreciate it
-_- to the above. If I wanted to just do the question for you I would have like above,haha. Just a note the term "indefinite integral" applies to integrals without boundaries, which this question has - in case you ever have to mention it on a test.
I decided to solve this one for him because i know that seeing it solved sometimes helps me a lot more than other things could, and what you were saying vsage was even confusing Me. :-p
Yeah I'm not the most coherent person in the world, sorry! -_-
  • · Replies 30 ·
