Need a little help with pseudocode
  • Thread starter Thread starter bsheltonihs
The discussion revolves around writing pseudocode for a nested For loop to generate a multiplication table from 1*1 to 10*10, specifically focusing on the correct implementation of a new line after every ten outputs. The scope includes programming concepts and pseudocode conventions.
  • Homework-related
  • Brad presents a pseudocode attempt and inquires about the correctness of his "new line" statement.
  • One participant suggests that the placement of the new line seems appropriate and encourages experimentation with the code.
  • Another participant notes that while the pseudocode is not strictly C++ or C#, it is acceptable to use a higher-level description and that the "write newline()" statement is acceptable.
  • Brad clarifies that he is working on pseudocode for a C++ class and contrasts it with C# syntax.
  • A participant explains that in C++, newline can be represented by "\n" or by using endl with cout, but emphasizes that pseudocode should focus on algorithm description rather than specific language syntax.
Participants generally agree on the appropriateness of the pseudocode structure, but there is no consensus on the best way to represent new lines in pseudocode, as different interpretations of pseudocode conventions are presented.
There is a lack of clarity on the formal conventions for pseudocode, as participants reference different programming languages and their syntax, which may lead to varying interpretations of what constitutes correct pseudocode.
Students learning programming concepts, particularly those interested in pseudocode and its application in algorithm design.
bsheltonihs
I am trying to write a nested For loop to display multiplication table from 1*1 to 10*10 but I need to output a new line after 10 items. I have this written so far and was wondering if my "new line" statement was correct.
Declare nb1, nb2 As Int
For (nb1 = 1; nb1 < 11; nb1++)
For (nb2 =1; nb2 < 11; nb2++)
Write nb1 * nb2 + " "
End For
Write newline( )
End For
Thanks for your help!
Brad
Outputting the blank line seems to be in the right place. You'll learn a lot more by "trying and seeing" for yourself than by having someone look over it. Do you have a programming language for which you can try this out?
I wonder are there any online sites where a short program can be run? Anybody know?
As your programs get larger and more complicated, it will help comprehension (and reveal some mistakes) if you get into the habit of indenting individual blocks of code, to wit:
Code:
    End For
    Write newline( )
End For
For the task at hand, you might need to add more detail to your line:
Code:
It for a Prelude to programming class for C++. I know that for C# this below would be correct but I just was unsure of the correct way for pseudocode for C++ on how to correctly create a new line. I have looked over my textbook and on the web and i have found nothing on creating a new line in pseudocode. So I took what i found and what i know to come up with the (Write newline " ").
for (int i = 1; i < 11; i++)
for(int j=1; j < 11; j++)
Console.Write( j * i + " ");
Console.Writeline();
In C++, you can either use the newline character "\n" or you can pass endl to cout:
Code:
cout << "some text" << endl;
// or
cout << "something\n";
For psuedocode, however, you generally don't want to actually write C++ code (or C# for that matter!), but rather a higher level description of the algorithm. You can borrow from a language's syntax, but really the way you write it is up to you, so the "write newline()" statement is fine.
Ok thanks for the help everyone!
  • · Replies 17 ·
