Falling Bodies - Does mass play a role?
The discussion revolves around the role of mass in the speed of free-falling bodies, particularly in the context of objects with the same volume and geometry but different weights. Participants explore the effects of air resistance and gravitational forces on falling objects, considering both theoretical and experimental perspectives.
  • Experimental/applied
  • Some participants argue that mass does not affect the speed of falling bodies in a vacuum, where air resistance is absent, and that all objects fall at the same rate regardless of mass.
  • Others propose that in the presence of air resistance, the mass-to-drag ratio is crucial, suggesting that heavier objects may fall faster due to their greater weight overcoming drag more effectively.
  • A participant illustrates the concept using cubes of different sizes, explaining how surface area relative to volume affects drag and falling speed.
  • Some participants note that while theoretically all objects fall at the same rate, the practical effects of mass and air resistance can lead to observable differences in fall times, especially in experiments designed to measure these differences.
  • There is a discussion about the negligible effect of the gravitational pull of falling objects on the Earth, with some suggesting that this effect is so small it can be ignored in most practical scenarios.
  • Terminal velocity is introduced as a concept that could further explain differences in falling speeds between objects of different densities.
  • One participant asserts that an iron ball will fall faster than a cork ball due to the greater weight and resultant forces acting on it.
Participants express differing views on whether mass affects the speed of falling bodies, particularly in the presence of air resistance. While some agree that mass plays a role in practical scenarios, others maintain that in a vacuum, all objects fall at the same rate. The discussion remains unresolved with multiple competing views presented.
Participants highlight the importance of experimental design to detect differences in fall times, suggesting that the margin of error in typical experiments may obscure small differences in falling speeds due to varying masses. The discussion also touches on the complexities of gravitational forces and their effects on falling objects.
CrashOv3r
Me and a few friends of mine were discussing if mass plays a role in the speed of a free falling body. They argued that equal bodies (same volume, same geometry) with different weights (mass) would fall at different velocities. I defended that mass has no part on the matter, but only air resistance. Meaning that if two equal balls (same radius), one made of iron another made of cork, were dropped from an airplane, both would reach the ground at the same time. I am aware that in vacuum as long as both bodies are dropped from the same height they will hit the ground at the same time, regardless the shape or weight. Since there's no air resistance. Was I right or wrong? Is air resistance affected by mass or just by the contact surface (geometry)?
I searched the forum for similar threads but couldn't find a straight answer.
Thanks
What's important is the ratio of mass to drag. If mass is large compared to drag, as in a vacuum, then both will hit at the same time. If mass is small compared to drag then they will not.
You know how fine sawdust will float in the air, but a solid piece of wood wont? A dust particle and a 2x4 are made of the same material so why does the 2x4 fall so much faster then the dust particle?
Answer: Imagine 2 cubes. 1 is 1 meter per side, the other is .1 meters per side...
1 meter cube has a volume of 1 cubic meter and a surface area of 6 square meters. ratio of 1:6
the 1 cm cube has a volume of 0.001 cubic meters and a surface area of 0.06. ratio of 1:60
So the smaller cube has far more surface area in relation to it's volume. Assuming constant density it also has more surface area per mass. Surface are is proportional to drag so it will have more drag per unit mass. If the particle is very small, like a dust particle the drag will be the dominant force and the particle will waft about with the air currents for a while before eventually settling to the floor.
So according to your explanation I was wrong. Even though in the situation I depicted the surface area is the same because both balls have the same radius the mass/drag ratio is different. The iron ball has a higher density and therefore a higher mass/ratio so it will reach the ground first, correct? Is this visible also for smaller heights?
Yes, although the short time periods involved might be hard to deal with.
One of the best ways to measure the difference is to set up an apparatus where the ball and a pendulum will be released at the same time. Put some paper along the pendulum. You can put carbon paper on top of the paper so the carbon paper will leave a mark where the pendulum struck the ball or cover the ball in chalk so it leaves a mark on the paper, etc.
You might have to vary the length of the pendulum so the ball doesn't hit the ground before the pendulum has time to strike it.
Just measure the difference between the dots.
For most experiments that you might do, such as wood vs. iron balls the difference in fall times will be smaller than the margin of error. To make the difference detectable you need to design your experiment so that the difference is large and/or the margin of error is small.
In a realistic sense, and ignoring air resistance, all objects fall at the same speed and accelerate the same amount.
However, I believe that a heavier mass, will have a slightly higher acceleration, but negligible.
The force of gravity is expressed by F = GMm/(r^2)
F = gravitational force, G = gravitational constant, M = attracting body's mass(like Earth), m = falling body's mass(like an apple), and r = radius from the center of mass.
Recall that F = ma, so a = F/m
Divide the gravitation force by m, so you get a = GM/(r^2)
Therefore all objects are attracted to an object at the same rate, determined only by the attracting body's mass and the distance from the center of mass.
However, Newton also says that for every force, there is an equal and opposite reactive force. So as the Earth pulls on the apple, the apple pulls on the Earth.
F(apple) = -F(Earth)
So if you find the gravitational acceleration of the Earth to the apple, you divide the M:
a = Gm/(r^2)
Therefore, the Earth accelerates to the apple.
Now, the Earth has an enormous mass compared to anything on it. I think the mass in kilograms is in the area of 10^31 or so. An apple, however, is less than 1 kg. The acceleration(relative to mass, the Earth's gravitational pull is only 9.81 m/(s^2)) is so tiny because G is tiny, about 6.67 x 10^-11. If an object as massive as the Earth only produces 9.81 m/(s^2), how much would the apple produce? The amount would be negligible, even if the falling mass weighed 10^5 tons. This is because the Earth's acceleration is so much larger that an difference is too tiny to measure.
In short, a heavier mass does technically fall slightly faster. However, in reality, this difference is very very very very very very very very very tiny, to the point of no effect.
Technically it does not fall faster; it falls at the same rate, but Earth rises to meet it, resulting in a shorter duration before impact.
Well yes, the Earth's gravitational pull is identical. When he said falling, I figured that would include both pulls, like if Earth and Venus were suddenly next to each other and pulled each other into a collision. In that case, the acceleration including both bodies(g[itex]_{e}[/itex]+g[itex]_{v}[/itex]) should be higher, right? However, if you only include the gravitational attraction of Earth, then the falling body would fall the same regardless of mass.
I suppose I should have specified that. Most people only take the Earth's acceleration into account for everything, since the field exerted by everyday objects is too small for much of anything, meaning there is no noticable difference of falling. I don't know if current technology can see any difference between ordinary everyday objects.
First get a leaning tower...
Compare a slowly falling balloon, with a solid iron ball of the same size...
Did not realize this question was as simple as it is.
CrashOv3r said:
... if two equal balls (same radius), one made of iron another made of cork, were dropped from an airplane, both would reach the ground at the same time.
No. The iron ball will fall much faster.
as the density of iron is more than cork, mass of iron ball will be more than that of cork ball. there are three forces acting on falling ball: weight, upthrust and viscous force. same upthrust acts in both bodies. so (weight - upthrust ) of iron is larger than of cork. and hence a larger viscous force is req to balance larger (weight - upthrust). by stokes law viscous force is directly proportional to velocity. hence there will be larger terminal velocity(velocity at equilibrium) for iron ball.
so it will fall faster.
  • · Replies 23 ·
  • · Replies 51 ·
  • · Replies 33 ·
  • · Replies 29 ·
10K
  • · Replies 30 ·
