Troubleshooting Air Volume Increase: -3.5°C to 37°C
The problem involves understanding the behavior of gas volume in relation to temperature changes, specifically when a person inhales air at a low temperature and holds their breath as the air warms to body temperature. The subject area includes thermodynamics and gas laws.
  • Participants discuss the calculation of the final volume of air using the gas law, question the implications of holding one's breath, and explore whether the volume or pressure changes as the temperature increases.
The discussion is ongoing, with participants examining different interpretations of the problem. Some suggest that the volume remains constant due to the act of holding one's breath, while others question the assumptions about lung capacity and pressure changes. There is no explicit consensus on the correct interpretation yet.
Participants note that the problem does not specify whether the lungs are filled after inhalation, leading to differing assumptions about the behavior of the gas in the lungs. There is also mention of the relationship between pressure and temperature in a confined volume.
mikep
can someone please help me with this problem?
After emptying her lungs, a person inhales 4.5 L of air at -3.5°C and holds her breath. How much does the volume of the air increase as it warms to her body temperature of 37°C?
i used the equation [tex]\displaystyle{\frac{V}{T}} = \displaystyle{\frac{V}{T}}[/tex]
[tex]\displaystyle{\frac{4.5L}{269.5K}} = \displaystyle{\frac{V}{310K}}[/tex] V = 5.18
but i got the wrong answer. can someone please tell me what I'm foing wrong?
You found the final volume. What is the question asking for...?
I think you'll see it. :smile:
oh ok i tried 5.2 - 4.5 = 0.7 but i still got it wrong
Ha! The question fooled us both. Upon re-reading, I realized that the volume will not increase because she is holding her breath. Pressure will increase.
Good fun.
wouldn't the pressure decrease? i tried 0 as an answer but it didn't work
No... the pressure Would increase because the volume tries to increase as temp increases, but the lungs confine it to the same volume...
so is the answer suppose to be 0?
as far as i can tell...
but i could easily be wrong... =/
well the question doesn't say that she fills her lungs. it just says she empties them and then breathes in 4.5 litres so I don't think you can assume her lungs are filled at this point. Unless you've been studing average lungcapacity or the pressure lungs exert on air then I think what you did in the first and third posts would be correct.
I don't think so. Remember that no matter how little air she takes in, it will spread to occupy the entire volume of her lungs because it is in gaseous phase. Once that happens, any increase in temperature will cause an increase in pressure according to:
[tex]PV=nRT[/tex]
When volume (V), amount of gas (n), and the constant (R), are constant, [itex]P~\alpha~T[/itex].
I think the answer should be 0.
21K
