How to increase pH of lime water
  • Thread starter Thread starter Caccioppoli
    increase Ph Water
The discussion revolves around the preparation of a calcium hydroxide (Ca(OH)2) solution with a target pH of 13.2. Participants explore the feasibility of achieving this pH using various additives, including sodium sulfate, sodium chloride, and sodium nitrate, alongside Ca(OH)2 and distilled water. The conversation touches on solubility limits, dissociation fractions, and the effects of ionic strength on pH.
  • One participant notes that the solubility of Ca(OH)2 at 25°C is 1.65 g/L, suggesting that achieving a pH of 13.2 may not be possible with just Ca(OH)2 and water.
  • Another participant questions the role of sodium sulfate, chloride, and nitrate in altering pH, suggesting that they may only increase ionic strength without significantly affecting pH.
  • A participant mentions the possibility of starting with a saturated Ca(OH)2 solution and adding NaOH to reach the desired pH, acknowledging that this may lead to precipitation of calcium.
  • One participant expresses skepticism about the suggested method of adding sodium salts, indicating that it seems strange and proposes adding NaOH instead.
  • Another participant discusses the distinction between solubility and dissociation fraction, suggesting that sodium salts might react with undissolved Ca(OH)2 to produce NaOH, potentially increasing pH.
  • A counterpoint is raised regarding the inability to alter the dissolution equilibrium of Ca(OH)2 by introducing Na+, as it does not change the concentration of OH- ions.
  • Further discussion includes the potential for calcium sulfate precipitation or sulfate complexation to affect solubility, but there is disagreement on whether this would still qualify as lime water.
Participants express differing views on the effectiveness of the proposed additives in achieving the desired pH, with no consensus reached on the validity of the suggested method or the role of sodium salts in the process.
The discussion highlights limitations related to the assumptions about the interactions between the various salts and Ca(OH)2, as well as the unresolved implications of complexation reactions on pH and solubility.
Caccioppoli
Hi to all,
I'm in this problem:
I've got to prepare a solution of Ca(OH)2 with pH=13.2 .
On Perry I read that the solubility value of Ca(OH)2 at T=25°C is 1.65 g/L, so a solution with water and Calcium Hydroxide cannot reach pH=13.2.
So I was suggested to prepare the mixture in the following manner:
distilled water + 4g Ca(Oh)2 + 1g Na2SO4 + 1g NaCl + 1g NaNO3 .
I'd like to know if this solution is correct and why.
Thank you very much,
Caccioppoli
I don't see how sodium sulfate, chloride and nitrate can help in changing pH (other than increasing ionic strength of the solution, but it won't change the result much).
Perhaps start with saturated Ca(OH)2 and add NaOH till pH goes up to 13.2? That will mean precipitating part of the calcium, but you can't cheat on Ksp.
Thank you very much for the answer.
An european guide line (etag) says that I have to prepare a solution with pH 13.2 having Ca(OH)2 powder and distillated water.
Since theoretically and experimentally I have verified that it is impossible to reach that pH, I asked for information.
They said that I have to add those substances in these quantities to obtain pH 13.2.
I have not yet prepared the mixture as they said, but for me is really strange, and I have thought about adding NaOH too.
By the way I think I should find an explanation for their suggestion.
If they say that's the standard procedure, you have not much choice but to try. I don't see how it can work, but can be I am missing something.
two issues at play that should not be conflated. first is the solubility of the species in water and second is the dissociation fraction.
with regards to the additions of sodium sulfate and nitrate ... it may have to do with the difference in dissociation fraction between sodium and calcium salts. the sodium salts, dissolved in water, may react with undissolved Ca(OH)2 to produce NaOH (which will dissociate to a large degree and increase pH) and soluble CaSO4/Ca(NO3)2.
I don't see how. You can't cheat on Ca(OH)2 Ksp. Introducing Na+ doesn't change OH- concentration, so it can't shift Ca(OH)2 dissolution equilibrium.
That's all not entirely true, as both Na+ and Ca2+ get complexed by OH- to some extent, so it is not only about Ksp - but these complexation reactions don't increase OH- concentration, so pH is not going up.
It can if calcium sulfate precipitates or if sulfate complexes the calcium. Complexing agents like sucrose can change the solubility of CaOH2. Ammonia can change the solubility of silver chloride, etc...
Right - but I have problems calling it the lime water after that.
9K
