Calculating Volume Using Archimedes' Principle
The discussion focuses on calculating the volume of a solid object using Archimedes' Principle, based on its apparent weights in ethyl alcohol and water. The apparent weight in ethyl alcohol is 15.2N, while in water it is 13.7N. The user attempts to set up equations based on the relationship between apparent weight, buoyant force, and density but encounters difficulty in isolating the volume. The solution involves using the densities of ethyl alcohol and water to derive the volume directly from the apparent weights.
  • Understanding of Archimedes' Principle
  • Knowledge of buoyant force calculations
  • Familiarity with density concepts
  • Basic algebra for solving equations
  • Research the densities of ethyl alcohol and water for accurate calculations
  • Learn how to apply Archimedes' Principle in various fluid scenarios
  • Explore the concept of buoyant force and its calculation
  • Study real-world applications of volume calculations in fluid mechanics
Students in physics, educators teaching fluid mechanics, and anyone interested in practical applications of Archimedes' Principle in volume calculations.
nix
An object is solid throuhgout. When the object is completely submerged in ethyl alcohol, its apparent weight is 15.2N. When completely submerged in water, its apparent weight is 13.7N. What is the volume of the object?
This is my attempt:
Weight of object in ethyl alcohol [Woe]= (density of alchohol[de])(volume of object)(gravity)
Weight of object in water[Wow] = (densityof water[dw])(volume of object)(gravity)
therefore:
Woe/de = Wow/dw
Woe/Wow = de/dw
15.2/13.7 = de/dw
but this is where i get stuck..because both the equations have volume and gravity they just cancel and i can't solve for either of the densities...
thanks for any hints.. :confused:
Apparent weight = real weight - buoyant force
Set up two equations, one for each liquid, and compare. You'll need the density of each liquid---look them up.
thank you :)
12K
