Find the spring constant and the amplitude of the simple harmonic moti
The discussion focuses on calculating the spring constant and amplitude of a mass-spring system undergoing simple harmonic motion. A 4kg mass with a period of 1.50 seconds and total mechanical energy of 12J leads to a spring constant of 22.4 N/m, derived using the formula K = (4π²m)/T². The amplitude is confirmed to be 0.585m, calculated from the energy formula E = (1/2)K*A².
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with the formulas for spring constant and mechanical energy
  • Knowledge of angular frequency and its relation to mass and spring constant
  • Basic algebra for rearranging equations
  • Study the derivation of the spring constant formula K = (4π²m)/T²
  • Explore the relationship between mechanical energy and amplitude in SHM
  • Learn about angular frequency and its calculation in oscillatory systems
  • Investigate real-world applications of simple harmonic motion in engineering
Students and educators in physics, mechanical engineers, and anyone interested in the principles of oscillatory motion and spring dynamics.
Flinthill84
Having a little trouble with this one:
A 4kg mass is attached to a spring and executes simple harmonic oscillation with a period of 1.50s. The total mechanical engery of the system is 12J. What is the spring constant. Determine the amplite.
I was able to find the amplitude which is 0.585m but am not able to find the spring constant. The formula that I have for spring constant you have to know the angular frequency so I do not think that is right. Can anyone help?
Use the equation of shm: [itex]x = A sin \omega t[/itex] where [itex]\omega = \sqrt{k/m}[/itex]
To find the spring constant in this situation, we can use the formula K = (4π²m)/T², where m is the mass and T is the period. In this case, m = 4kg and T = 1.50s. Plugging these values into the formula, we get K = (4π² * 4kg)/(1.50s)² = 16π²/2.25 = 22.4 N/m. So the spring constant in this system is 22.4 N/m.
To determine the amplitude, we can use the formula E = (1/2)K*A², where E is the total mechanical energy and A is the amplitude. Rearranging for A, we get A = √(2E/K). Plugging in the values for E and K that we just found, we get A = √(2*12J/22.4 N/m) = 0.585m. So the amplitude of the simple harmonic motion is 0.585m.
I hope this helps!
