Help Needed: Calculating Coal Delivery Rate with 60kW Motor
  • Thread starter Thread starter steelcap
    Coal Motor Rate
The discussion focuses on calculating the coal delivery rate using a 60kW motor, where only 90% of the power is available for work. The formula derived involves using potential energy considerations, specifically the equation m = (Pt) / (gh), where P is the effective power, t is time, g is the acceleration due to gravity, and h is the height of the hopper (19.5m). The efficiency of the motor must be factored in, leading to the effective power being 54kW (60kW * 0.90).
  • Understanding of basic physics concepts, particularly potential energy
  • Familiarity with power calculations in mechanical systems
  • Knowledge of efficiency calculations in motors
  • Basic algebra for manipulating equations
  • Research the principles of potential energy and its applications in mechanical systems
  • Learn about motor efficiency and how it affects performance
  • Explore advanced calculations involving power, work, and energy transfer
  • Investigate real-world applications of conveyor systems in material handling
Students in engineering or physics, mechanical engineers, and anyone involved in the design or analysis of conveyor systems and motor efficiency.
steelcap
Hey everyone, just wondering if anyone can help me out with a homework question I'm having trouble with. I've been stuck on it for about 45 minutes now, any help will be appreciated. Thanks.
"A conveyor belt is driven by a motor rated at 60kW. Only 90% of the rated power is available for useful work. The coal is to be raised and deposited into a hopper 19.5m above. How many kilograms of coal can be delivered by this motor per minute?"
- Matt
If you use t = 60s, then find the mass through work/potential energy considerations.
[tex]P = \frac {W}{t}[/tex]
[tex]W = mgh[/tex]
[tex]P = \frac {mgh}{t}[/tex]
[tex]m = \frac {Pt}{gh}[/tex]
Dont forget to forget to multiply the power by the motor's efficiency!
