lucifer
- 15
momentum problems
it's be really cool if someone could help me out with the following two momentum problems. nothing much just enough to get me started. i have ideas but I'm not quite sure about what's the right way to go about doing them. also want to say hi to all the people here. must say the whole homework help thing is a very neat concept.
problem 1- A 25 kg child is in a 10 kg sled that travels 1m/s east on ice. The child throws a 3 kg snowball at 40m/s at an angle of 50 degrees north of east. Find the velocity of the sled after the snowball leaves the child's hand.
problem 2- A 2kg block and an 8-kg block are both attached to an ideal spring (for which k=200 N/m) and both are initially at rest on a horizontal frictionless surface.
In an initial experiment, a 0.1 kg ball of clay is thrown at the 2kg block. The clay is moving horizontally with speed v when it hits and sticks to the block. the 8-kg block is held still by a removable stop. As a result, the spring compresses a maximum distance of 0.4 meters. Find:
a) the energy stored in the spring at max compression.
b) speed of the clat ball and 2-kg block immediately after the clay sticks to the block but before the spring compresses significantly.
c) the initial speed v of the clay.
