Pressure and Net Force Question
The discussion focuses on calculating the net force on a porthole of a bathyscaph at a depth of 7.72 miles, where the absolute pressure is 1.25484 x 10^8 Pa. The second part of the problem involves determining the net force using the equation F = PA - Pinitial(A), where PA is the atmospheric pressure of 101300 Pa and A is the area of the porthole. The correct calculation yields a net outward force of -1.25483 x 10^7 N, indicating that the internal pressure exceeds the external pressure, resulting in an outward force.
  • Understanding of pressure calculations in fluid mechanics
  • Knowledge of the formula F = PA for force calculations
  • Ability to convert units, specifically from centimeters to meters
  • Familiarity with concepts of absolute pressure and net force
  • Research the principles of fluid statics and hydrostatic pressure
  • Learn how to calculate the area of a circle for pressure applications
  • Explore the concept of buoyancy and its effects on submerged objects
  • Study real-world applications of pressure calculations in engineering
Students studying physics, particularly those focusing on fluid mechanics, engineers involved in underwater vehicle design, and anyone interested in pressure-related calculations in practical scenarios.
Enoch
I'm working on my homework, and I have finished all the problems save for one. I think I am on the right track, but I'm lacking just a few bits of info. Here is the question (it has 2 parts, I have answered the first part correctly, but cannot get the second part correct).
Part 1
Engineers have developed a bathyscaph that can reach ocean depths of 7.72 mi. The acceleration of gravity is 9.8 m/s^2. If the density of seawater is about 1030 kg/m^3, what is the absolute pressure at that depth in Pa?
Answer - P = Pinitial + pgh = 1.25484 x 10 ^8
Part 2 (here is where I need help)
If the inside of the vessel is maintained at atmospheric pressure, 101300 Pa, what is the net force on a porthold of diameter 20.9 cm? Answer in units of N.
Well I know that F = PA, so I set up the equation:
PA - Pinitial(A) = density(g)(h)(A)
However, this doesn't solve for net force. I'm not sure if this is the actual equation I need, or if I can use it to find the net force. I was under the impression that PA - Pinitial(A) would equal the net force but it does not. I assume that I need the 20.9 cm in there somewhere. Any help is appreciated.
It seems like you are on the right track for part 2, but there are a few things to consider. First, make sure you convert all the units to be consistent. In part 1, you used meters for depth, so make sure to use meters for the diameter as well. Also, the pressure at the porthole will be the same as the atmospheric pressure, so you can set PA equal to 101300 Pa.
Now, for the equation, you are correct that F = PA - Pinitial(A) is the correct formula. However, you need to consider the area of the porthole as well. Since the pressure is acting over the entire area of the porthole, you need to multiply the pressure by the area. The equation would then be:
F = PA - Pinitial(A) = (101300 Pa)(0.209 m^2) - (1.25484 x 10^8 Pa)(0.209 m^2) = -1.25483 x 10^7 N
Note that the net force is negative because the pressure inside the vessel is higher than the pressure outside, creating a force pushing outwards. This is known as the "net outward force" and is a common concept in pressure calculations.
I hope this helps to clarify the equation and how to incorporate the diameter to find the net force on the porthole. Good luck with the rest of your homework!
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 23 ·
