What is the correct approach to solving this integral?
  • Thread starter Thread starter QuarkCharmer
    Integral
The discussion revolves around the integral of the function \(\int \frac{e^{2x}}{e^{2x}+3e^{x}+2}dx\), focusing on the methods of integration and the validity of the approaches taken by participants.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of partial fraction decomposition and question the appropriateness of this method given the degrees of the numerator and denominator. Some suggest using substitution to simplify the integral before applying partial fractions. Others explore the relationship between different logarithmic forms of the solutions presented.
The discussion is active, with participants sharing various perspectives on the approaches to the integral. Some express uncertainty about the correctness of their methods, while others provide insights into the equivalence of different logarithmic expressions. There is no clear consensus on a single method, but several productive lines of reasoning are being explored.
Participants note the potential confusion arising from the degree of the numerator being equal to that of the denominator, and the implications this has for the integration process. There are references to specific solutions and the properties of logarithms that may affect the interpretation of results.
QuarkCharmer
[tex]\int \frac{e^{2x}}{e^{2x}+3e^{x}+2}dx[/tex]
I don't understand what I am doing wrong here. I missed this one question on a quiz but it looks right to me, I have went over it a dozen times.
Fraction part:
[tex]\frac{e^{2x}}{(e^{x}+1)(e^{x}+2)} = \frac{Ae^{x}}{e^{x}+1} + \frac{Be^{x}}{e^{x}+2}[/tex]
[tex]e^{2x} = e^{2x}(A+B)+e^{x}(2A+B)[/tex]
[itex]A + B = 1[/itex]
[itex]2A + B = 0[/itex]
[itex]A=-1[/itex] and [itex]B=2[/itex]
Integral stuff:
[tex]\int -\frac{e^{x}}{e^{x}+1} + \frac{2e^{x}}{e^{x}+2}dx[/tex]
My solution:
[tex]-ln(|e^{x}+1|) + 2ln(|e^{x}+2|) + C[/tex]
??Edit: Additionally:
If one of the factors were (e^(2x)+1), does that count as a non-reducible polynomial and get A(e^x)+B as it's numerator instead of just plain A?
It's as if the numerator of the integrand is of the same degree as the denominator. Use long division, or the following trick to reduce the "improper fraction", to a "mixed fraction".
[itex]\displaystyle \frac{e^{2x}}{e^{2x}+3e^{x}+2}=\frac{e^{2x}+3e^{x}+2}{e^{2x}+3e^{x}+2}-\frac{3e^{x}+2}{e^{2x}+3e^{x}+2}[/itex]
[itex]\displaystyle =1-\frac{3e^{x}+2}{e^{2x}+3e^{x}+2}[/itex]​
Now use partial fractions.
Fraction part:
Integral stuff:
My solution:
I think you already have a correct solution there. It's a little unconventional, I think most people would substitute u=e^x first and then work with the polynomials in u. But I think you pulled it off.
Oh yeah, a sub would have made that a bit less annoying. Is it still correct though that I did the partial fraction decomposition when the degree of the num/den were equal?
For reference, the "correct" solution was:
[itex]ln(\frac{(e^{x}+2)^{2}}{(e^{x}+1)})+C[/itex]
But I am not seeing how you can use the properties of log to equate that to my solution?
QC,
I didn't look at your complete solution. I looked at your title & just suggested the usual first step to take before doing partial fractions.
Your solution is very interesting. I like it !
You did a correct decomposition of the integral into two things you can integrate. I wouldn't exactly call it 'partial fractions' but it works. The only rules of log you need to show they are equal are things like log(a^b)=b*log(a) and log(a/b)=log(a)-log(b). You know those, right?
Yeah I know those, but I don't have a condition like that (at least it's not apparent to me).
I have:
[itex]ln(a) - 2ln(b) = ...[/itex]
I couldn't figure out how to get rid of that 2.
Edit: Oh wait, you used that property to stick it back up into the exponent... That's where they got that squared term from. I never would have considered that lol. I just use that one to pull things down.
I have:
Right, use it to put the exponent back up.
I would argue for your points.
what you had and the answer are equivilent.
-ln(a) + 2ln(b) = ln(a[itex]^{-1}[/itex]) + ln(b[itex]^{2}[/itex])
= ln((a[itex]^{-1}[/itex])(b[itex]^{2}[/itex])) = ln ([itex]^{b^{2}}_{a}[/itex])
  • · Replies 105 ·
13K
  • · Replies 18 ·
