Calculating the Elasticity of an Annular Disc Without Prior Information
  • Thread starter Thread starter umer_majid
    Disc Elasticity
The discussion focuses on calculating the elasticity of an annular disc without prior material information. Key methods suggested include using finite element analysis (FEA) to model the geometry and obtain a force/displacement response, performing nanoindentation to measure stiffness, and conducting uniaxial testing on a cut rectangular section of the material. Additionally, a non-destructive approach is mentioned, where the disc can be clamped at both sides of one radius to test for Young's modulus if the material is not plastic.
  • Understanding of finite element analysis (FEA) techniques
  • Knowledge of nanoindentation methods for material stiffness measurement
  • Familiarity with uniaxial testing procedures
  • Basic principles of elasticity and Young's modulus
  • Research finite element analysis software options for modeling annular discs
  • Learn about nanoindentation techniques and equipment
  • Explore uniaxial testing standards and protocols for material analysis
  • Study the principles of elasticity and methods to measure Young's modulus
Material scientists, mechanical engineers, and researchers involved in material characterization and elasticity testing will benefit from this discussion.
umer_majid
Hi,
I have an annular disc that looks like the following:
I need to get the elasticity of the material, since I don't have any information on it. Does anyone have any suggestions on how I can calculate the elasticity?
Maybe I can get a force/displacement curve by bending the disc (held at the center)? I have equipment to do that. But how can I use that information to get the modulus?
Any help will be appreciated :)
Thanks & Regards,
Umer
Hi umer_majid, welcome to PF!
One approach is to model the geometry by finite element analysis, obtain the force/displacement response, and match that to experiment. Another is to find someone to perform nanoindentation on the material to measure its stiffness. Another (destructive) method is to cut out a rectangular section and perform uniaxial testing on it.
I don't know the dimensions of your annular disc, but if you only need Young module and the material is not plstic (no linear elasticity) , may be you can try test without cut. Use the clamp to clamping at both sides of one radio.
17K
  • · Replies 87 ·
