Maximizing Bridge Capacity: A Weight Distribution Dilemma
  • Thread starter Thread starter iknownothing
    Bridge
The discussion revolves around a hypothetical scenario involving crossing a bridge with a weight limit while carrying gold bars. Participants explore various strategies to maximize the bridge's capacity without exceeding the weight limit, considering both physical and creative solutions.
  • Some participants suggest breaking the gold bars into smaller chunks to make multiple trips across the bridge.
  • Others propose waiting to lose weight or removing clothing to reduce total weight while crossing.
  • A few participants mention creative methods such as using ropes or jumping to synchronize weight distribution.
  • One participant questions the feasibility of breaking a gold bar with a rock, arguing that it may not be practical.
  • Another participant humorously suggests simply walking back instead of crossing the bridge.
  • Some participants express skepticism about the physical assumptions in the puzzle, particularly regarding weight and jumping.
There is no consensus on a definitive solution, with multiple competing views and strategies presented. Participants express differing opinions on the practicality of various methods and the assumptions underlying the puzzle.
Participants note limitations in the problem's assumptions, such as the lack of clarity on the use of tools or props and the physical feasibility of certain proposed solutions.
iknownothing
My first post... So be nice, or I'll blast you with a phaser... o:)
You are at one side of a canyon at the start of a bridge. The only way to cross the canyon is over the bridge. (no tricks to this, just a normal crossing of the bridge, don't try to walk on water here) On you side are 3 gold bars, each weighing 3kg. You weigh 78kg. The bridge can only support 80kg without breaking. How do you get yourself across with your new found wealth, without falling through the bridge?? --And no, you can't throw it across.
as far as the question goes i know that it has to do with applied force and kinetic energy but the math is beyond me.
You wait until you weigh an ounce.
...or at least 7 kg lighter. Then go across with the gold bars.
true enough but i think that there is an impetus of time involved? where the person needs to be across within a certain time frame that doesn't allow one to wait until they are emaciated. good try! :)
break up the gold bars into smaller chunks and make several trips
each time taking a chunk weighing less than 2 kg
Go round?
either that, or put the gold bars in your bag, cut the ropes of the bridge, and swing across indiana jones style, before undertaking a daring climb up the other side.
(in other words, I havn't the foggiest idea!)
I think I've got it.tie a rope to the bricks, walk across the bridge then pull the bricks across..
so what is the answer?
I gave it in white letters in the post above yours. you have to select it to see it.
Nah, I think this is the answer (in white text):
You have to perfectly synchronize your jumping (or hopping) across the bridge with your juggling of the gold brick so that you aren't touching the brick when you're touching the bridge. You better practice it a bit before trying it for real, it would require immense coordination.[/color]
I'm sure if you can induce enough vomit you can lost a kg. Then make trips with one gold bar at a time. But be sure to brush your teeth afterwards.
Maybe...
Take off all your clothes, then walk with one bar at a time.
Not sure if you were serious tribdog, but this won't work:
"...You have to perfectly synchronize your jumping (or hopping) across the bridge..."
If you could actually decrease your weight by continually jumping, a lot of people would be doing it instead of dieting. Your weight will far exceed 80kg every time you land.
Personally, breaking the bricks in half is the most plausible solution. This problem doesn't indicate if you can use props, like tools to chop, melt or otherwise dissassemble anything. Just seems a little simplistic for a puzzle.
Then again, if you can use props, the rope trick would work just fine.
I wasn't the one who came up with that solution. That was moonbear.
But in the puzzle, my weight alone is only 78 kg, not 80 kg. Do you think the puzzle would take into account real physics? I wasn't reading that deeply into it.
Though, actually, continually jumping is an excellent way of losing weight. If more people jumped continuously, they wouldn't need to diet! :smile:
But, aha! Working together can help sometimes...maybe the solution is to jump around for a while, run back and forth the bridge a few times, pee, whatever, until you've lost a kg, then you can just walk across carrying the gold with no problem.
Then again, no gold is worth walking across a bridge with a weight limit within only 2 kg of my weight! I want to see those error bars first! :biggrin:
when I suggested this back a ways in post #5 of this thread, i didnt think anybody would be wondering how you'd break a gold bar in half-----if you found one in a canyon
canyons have rocks. I'd put the bar between two rocks and chop it in the middle with a third rock.
how big is a 3 kilo gold bar?
gold is 19 times denser than water so the volume of a 3kg bar is about 1/6 of a liter.
that is less volume than an ordinary kitchen measuring cup
and gold is soft, so I think that volume of gold formed into a bar
would be something you could hack or bust in half without too much trouble
warn moonbear not to jump on a fragile bridge
Well, if you can hack it or bust it in half in the middle of the woods, surely you can also stretch it into a very fine wire, long enough to make about twice the length of the bridge. Grab one end, leave the other end behind and you have no more than half the weight of the brick with you on the bridge when you are at the other side. Then just pull the rest across. On the downside, be very careful not to get a tangle in the wire, or you'll drag the whole clump onto the bridge and fall to a horrible death.
Aye aye cap'n! :-p
Out of curiosity, how did I get to the side of the bridge I'm on anyway? I have to cross the bridge to get to the other side of the canyon, but is that the right direction to get home? Maybe all I need to do is grab my three bricks of gold, toss them in my backpack, and turn around and walk back out the way I came from. :biggrin:
One time I was out camping and when dinner time came I grabbed a can of chili then realized I didn't have a can opener. I beat the hell out of that can trying to open it. That can got the best of me and I had to settle for chips for dinner. My point is: you can't break a bar of gold with a rock. Go grab a rock and break a silver dollar in half and I'll believe you could break the gold.
Sorry Guys and Gals,
I really don't have an answer to this one. I put it here hoping to find a physics answer. But I like the one saying don't cross the bridge, just walk the other way.
...Then again, could you create a rope to drag the bricks by pulling pieces of the bridge off? ...I've never made rope, but I'm sure I could if there were 3 gold bricks wanting me to! :smile:
First you need to find the right type of rock, then find another rock, and chisel the rock into a spear point, try not to smash your fingers with either rock or cut your hand open on the sharp edges, then, no problem, you have a can opener. :biggrin: I used to carry around one of those 10 cent can openers you can buy in army surplus stores that goes on your keychain. Stopped carrying it when they banned anything with a point on it from airlines since I fly a lot and would forget to take it off the keychain. You'd be amazed how often you find yourself in the middle of the woods in need of a can opener. :-p You could have tossed the can on the campfire and when it exploded, then retrieve the chili...just don't stand too close when you do that. I hear chili can shrapnel really burns! :smile:
Well, since that was my answer, okay, I'll forgive you for sending us a question with no known answer.
:biggrin:
Be practical, throw it across (in acknowledgment of this reference in the first post).
If you can bend it back and forth, then you can break it.
Metal fatigue.
I am pretty sure i can break a silver dollar with pliers. by bending it back and forth several times
but with a bar of gold, I count on it being longer. so I can use cruder tools to bend it this way and that, until it breaks
9kg of gold at ~$450/oz (near current futures price) = $142,857 or $47,619/bar. Pretty serious incentive to get across the bridge, and presumably to the nearest bank, commodities broker, or precious metals dealer.
Actually a similar problem had one tie rope to the load, lower the bars to the bottom of chasm (assuming rope long enough to reach down to bottom of chasm, but not long enough to reach across the bridge), cross bridge (hopefully with less than 2 kgs of rope) and pull load up other side. Otherwise, if rope longer than bridge, tie rope to bars, cross brigde and pull bars with rope over bridge. Maybe one needs to fashion a cart or litter to hold the bars.
Certainly one could remove 1 kg of clothing and carry each bar across, if there is not a constraint on the number of trips.
But what if one does not have a rope. Well bury the gold and return later with a rope.
Or just use one's cell phone, which everyone seems to have, and get a helicopter to pick one up.
I held a bar of gold once. It was about 80lbs. no way I could have busted it. I'm pretty sure that my original answer is the correct one and the question was probably written wrong.
Actually, it's hard to find gold bars even 1 kg. Most that are commonly available are far smaller than that. Which means you're hallucinating the whole thing, the bridge doesn't really exist, and if you try to cross it, you're going to fall into the gaping chasm. :smile:
i think we are missing some basic facts here.
first, how do we know that the gold bar is actually pure gold, and the more impure it is, the harder it is to break it.
secondly, how did three gold bars weighing exactly 3 kgs, come there, obviously someone must have lost it. if so, why did he not come back for it.
also, if someone dropped them, then the way that he did not notice it, would be if he was carrying a large no. of bars. in that cas3e, how did he cross the bridge. if he used some other route, why not use the same.
and we know that he has not fallen into the canyon, as nobody would be supid enough to commit suicide, wtih that amount of gold,( i assume that he had far more gold than 9 kgs) and if he fell into the canyon trying to cross the bridge, then the bridge would have collapsed, which is not the case here.
so this problem has far too many problems(errors) to be solved.
Ok, as I said in the first post, ... no tricks to this. This problem has mathmatical and physics type answer. I figured I could find someone ingenious enough here to give me that. I guess I'm wrong.
you've gotten several answers. What did you expect? We gave as good of answers as MacGyver could have come up with.
No we didn't! You forgot the duct tape! MacGuyver doesn't do anything without duct tape...or was that the A-Team? :confused:
  • · Replies 30 ·
10K
  • · Replies 45 ·
10K
11K
  • · Replies 33 ·
11K
