Linear independence and decompostion
The method of decomposition applied to the solution set of a homogeneous linear system consistently results in a linearly independent set of vectors. This is due to the nature of the reduced row echelon form (RREF), which eliminates dependencies among vectors, ensuring that only independent spans remain. The discussion emphasizes that dependent spans cannot exist within this framework, as any dependencies would be resolved during the RREF process, leading to a definitive solution.
  • Understanding of homogeneous linear systems
  • Familiarity with the concept of linear independence
  • Knowledge of reduced row echelon form (RREF)
  • Basic linear algebra concepts
  • Study the properties of homogeneous linear systems
  • Learn about the implications of linear independence in vector spaces
  • Explore the process of obtaining reduced row echelon form (RREF)
  • Investigate the relationship between span and linear dependence
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators seeking to clarify concepts related to linear independence and decomposition methods.
MotoPayton
Explain why the method of decomposition when applied to the solution set of a homogeneous linear system always yields a linearly independent set of vectors whose span is the set of solutions...
Can someone explain this it seems reasonable but I can't seem to prove it to myself
Maybe dependent spans do not exist because if that were to be the case the dependence would work itself out in the rref as a definite solution removing the dependence. So only independent spans form...
Maybe if you explain to us what the method is, we can help you better, and, in doing the explaining, you may understand things better yourself.
  • · Replies 23 ·
  • · Replies 30 ·
  • · Replies 19 ·
