Solving Second Order Differential Equations with Initial Value Problem
  • Thread starter Thread starter rbailey5
    Second order
The discussion focuses on solving a second-order differential equation with an initial value problem (IVP) represented by the equation y(t) = Ce^-t*cos(4t) + Ce^-t*sin(4t). The initial conditions provided are y(0) = 1 and y'(0) = -1. The correct approach involves determining the constants C1 and C2, where C1 is found to be 1. The next step requires calculating the derivative y'(t) and setting y'(0) = -1 to solve for C2.
  • Understanding of second-order differential equations
  • Familiarity with initial value problems (IVP)
  • Knowledge of differentiation techniques
  • Basic grasp of exponential and trigonometric functions
  • Learn how to derive solutions for second-order linear differential equations
  • Study methods for solving initial value problems (IVP)
  • Explore the application of Laplace transforms in differential equations
  • Investigate the role of constants in the general solution of differential equations
Students studying differential equations, mathematicians, and anyone involved in solving initial value problems in applied mathematics.
rbailey5
I have got the diff equ problem solved out to
y(t)=Ce^-t*cos4t+Ce^-t*sin4t
now I have to solve for the IVP and the values are y(0)=1, yprime(0)=-1
I believe for the first part I just plug in the y(0)=1 which results in the e^-t dropping out
coming out to be C=1 but I am not 100% on it.
Then I am assuming I take the derivative and solve for the next value.
Are you sure those shouldn't be two different constants, as in y(t) = C1 e-t cos(4t) + C2 e-t sin(4t)
Then, you found that C1 = 1.
Now find y'(x) , then set y'(0) = -1 & solve for C2 .
  • · Replies 33 ·
