Is <Z,+> with <Z,+> a valid isomorphism? Why or why not?
  • Context: Graduate
  • Thread starter Thread starter SqrachMasda
The discussion revolves around the validity of various mappings (isomorphisms) between the group of integers under addition, , and itself, as well as other structures. Participants explore whether specific functions, such as theta(n) = -n, theta(n) = 2n, and theta(n) = n + 1, qualify as isomorphisms based on properties like injectivity and surjectivity.
  • Some participants assert that theta(n) = -n is an isomorphism, while others agree it is valid.
  • There is contention regarding theta(n) = 2n, with some arguing it is not surjective since it cannot map to odd integers, while others suggest it might be an isomorphism under certain interpretations.
  • Participants discuss theta(n) = n + 1, with at least one noting it fails to satisfy the isomorphism criteria.
  • Additional mappings, such as alpha: -> and gamma: -> , are mentioned, with varying degrees of clarity on their isomorphic properties.
  • Some participants express uncertainty about the definitions and implications of terms like "binary structure" and "C*".
Participants do not reach a consensus on the validity of the mappings discussed. Multiple competing views remain, particularly regarding the surjectivity of theta(n) = 2n and the interpretation of the mappings.
There are limitations in understanding the terminology used, such as "first binary structure with the second," which may affect the clarity of the discussion. Additionally, some participants acknowledge their uncertainty about specific mathematical properties and definitions.
SqrachMasda
1-3) determine whether the given map (theta) is an isomorphism of the first binary structure with the second. If it is not an isomorphism, why not?
1) <Z,+> with <Z,+> where theta(n)= -n for n elements in Z
2) <Z,+> with <Z,+> where theta(n)= 2n for n elements in Z
3) <Z,+> with <Z,+> where theta(n)= n+1 for n elements in Z
4) Let alpha: <Z4,+> -> <Z#5,X> by alpha(0)=1, alpha(1)=2, alpha(2)=4, alpha(3)=3. Prove alphais an isomorphism of groups. (verify 16 equations).
5) Let gamma:<C*,X> -> <R+,X> by gamma(a+bi)= a^2 + b^2. Prove gamma is a homomorphism.
6) Let theta: <Z,+> -> <{+/-1,+/-1},X> by theta(k)=i^k. Prove theta is homomorpism.
7) Let G be a group. Prove that alpha:G->G by alpha(a)=a^2 is a homomorphism if and only if G is abelian.
1-3) I don't know what "first binary structure with the second" means, but the first two are isomorphisms. The third isnt: try theta(a+b)=theta(a)+theta(b)...
5) gamma(1) = 1
gamma( (a+bi)*(c+di) ) = ... = gamma(a+bi)*gamma(c+di)
I didn't work this out so I'm not sure if it works...
(a+bi)' = 1/(a+bi) = a/(a^2+b^2) - bi/(a^2+b^2)
gamma( a/(a^2+b^2) - bi/(a^2+b^2) ) = ... = 1/(a^2 + b^2)
Again, I didn't work this out so I'm not sure if it works...
Also I'm not sure what C* means so I'm not sure what affect this has on the problem...
i think by binary structure it's just the structure <Z,+> where + is the binary operation, mapping it to itself by the function f(n)=-n , thanks again. I can see the answers but i am not good with proofs, for these three
the 2nd one is not, the ans in the book reads
No, because theta does not map Z onto Z'. theta(n) is not equal to 1 for all n in Z.
thanks again, it's very helpful,...i'll have 4 more in an hour
thanks a lot, appreciate it.
I'm not sure what that means, but:
f(x) = 2x
injective: f(x) = y & f(x') = y -> x = x' -> 2x = 2x' ->...-> x=x'
surjective: you know that if y is an even integer then it is equal to 2x for some x, where x is an integer...
the last part is showing that f(x+y) = f(x) + f(y), pretty straight forward...
ok thanks again
The second on is not an iso. since it is not surjective.
Take, for example, 1 in Z. If (2) was surjective, then we could find an n in Z such that 2n = 1. In otherwords we need n=0.5 which is not in Z. So not surjective and so not an iso.
(7) is quite straight forward.
Let a, b be in G. Then alpha(a)alpha(b) = (a^2)(b^2) and alpha(ab) = (ab)^2 =abab. Clearly this only equals (a^2)(b^2) (and hence meaning alpha is a homomorphism) if you can "swap" the order of multiplication of the elements around, ie, if the group is abelain.
f:A->B
f(x)=2x
surjective: for every y of B, there exists an x of A such that f(x)=y
Your example doesn't fit this criteria as 1 is not in B. However, you know that if y is an even integer then it is equal to 2x for some x, where x is an integer...
I may be missing something or misreading the notation, but under normal circumstances, f(x)=2x is an isomorphism for integers under addition.
I don't know what this means, but I get the impression that it is not asking for normal isomorphisms, so what I previously posted may not apply...
nnnnnnnn said:
f:A->B
f(x)=2x
Unless I'm the one to have missed something, then you are the one that is wrong. In (2) we a function f: Z ---> Z where f(n) = 2n. For this map to be an isomorphism from Z to Z we need it to be surjective. That is fro any integer y in Z we have an x in Z such that f(x) = y. Since f maps only to the even integers (i.e. the image of f is the even integers), there is no such x that maps to the odd integers. As such the map is not surjective.
If I'm right you are making the mistake of trying to show the map is surjective onto the image of the map, which clearly is the case, but this is not what the questions wants. Instead you need to show f maps ontot he whole of Z.
Yes, that's what I was doing... I see my mistake now, I was trying to prove it for Z->2Z.
  • · Replies 21 ·
  • · Replies 26 ·
