A charged rod transfers electrons to a neutral conductor
The problem involves a neutral conductor with a hollow cavity containing a +65.0 nC point charge, which receives -75.0 nC from a charged rod. Participants are discussing the resulting charge distributions on the inner and outer surfaces of the conductor.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the principles of charge distribution in conductors, questioning how the charges will arrange themselves given the presence of the point charge and the transferred charge. There are discussions about the implications of having zero electric field inside the conductor and how that affects the charges on the surfaces.
Some participants express understanding of the charge distribution principles, while others seek clarification on specific charge values and their implications. There is a mix of agreement and questioning regarding the calculations and assumptions made about the inner and outer surface charges.
Participants are navigating through assumptions about charge conservation and the behavior of electric fields within conductors. There is a noted confusion regarding the net charges and their distribution, particularly in relation to the hollow cavity and the outer surface of the conductor.
RichardEpic
An initially neutral conductor contains a hollow cavity in which there is a + 65.0 nC point charge. A charged rod transfers - 75.0 nC to the conductor.
Afterwards, what are the charges along the inner surface and the exterior surface?
I understand that the charges from the rod are equally distributing itself across the
volumes, but I don't know how the numbers will play into this...at all. I do know that the
inner wall surface should be negative due to the 65nC point charge, and the outside must
be positive due to the fact that this is a neutral conductor.
ANY formulas dealing with this type of problem would be greatly appreciated!
Remember that the charge distribution throughout a conductor will arrange itself according to two principles:
1. The charges will align such that there is no net electric field inside the conductor.
2. Any net charge will be stored on the outer surface of the conductor in a manner dependent on its geometry.
If you remember your equations for E and your conventions for electric-field lines, you should be able to solve the problem from there.
Ah, I think I'm understanding this now...I do know that the meat a conductor has an E-field of zero (E = 0). So, since the net charge only stays apparent on the exterior surface...would the interior surface charge stay the same? -65nC, in order to block the E-field of the +65nC point Charge?
Also, net charge on the surface should then be +65nC - 75nC = -10nC...correct?
THANK YOU! The world of Conductors has been made clearer to me! Answers were correct. :)
Unless I missed something in the problem, you've got it, and yes, the net charge on that outer surface should be -10C. :)
correct me if i am wrong, since the hollow cavity of the conductor is +65, the wall of the hollow part of the conductor is -65, so it stay neutral and the outer surface of the conductor is also +65
if this is true hen way isn't inner wall of the hollow part -130
Do you realize that this is an old thread?
If a charge of -75 nC is transferred to a neutral object, the object will have a net charge of -75 nC after the transfer .
The electric field within the conducting material itself is zero, thus Gauss's Law tell us that the net charge on the inner surface (the surface of the cavity) must remain at -65 nC, the same as prior to the transfer.
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 21 ·
