How Do I Solve for Both c and r in a Complex Impedance Equation?
  • Thread starter Thread starter zekester
    Variables
The discussion focuses on solving for the variables "c" and "r" in the complex impedance equation given by ((r^2)*(-i/(w*c)))+(r/(w*c)) divided by (r^2) + (1/(wc)^2) equals -951 - (i*13026). To derive two equations, participants suggest equating the real and imaginary parts of the equation, leading to the equations \frac{\frac{r}{wc}}{r^{2}+\frac{1}{(wc)^{2}}}=-951 and -\frac{\frac{r^{2}}{wc}}{r^{2}+\frac{1}{(wc)^{2}}}=-13026. The solution process involves multiplying through by the denominator, simplifying, and using substitution or a graphing calculator to find the values of "c" and "r".
  • Understanding of complex numbers and impedance
  • Familiarity with algebraic manipulation and equations
  • Knowledge of the properties of real and imaginary parts
  • Experience with graphing calculators or systems of equations solvers
  • Study the principles of complex impedance in electrical engineering
  • Learn about algebraic methods for solving simultaneous equations
  • Explore the use of graphing calculators for solving complex equations
  • Investigate the application of complex numbers in circuit analysis
Electrical engineers, physics students, and anyone involved in circuit analysis or complex number applications will benefit from this discussion.
zekester
i have an equation ((r^2)*(-i/(w*c)))+(r/(w*c))
where i is the square root of negative one and w is known. How do I get two equations to solve for both c and r.
Assuming "r" and "c" to be real numbers, equate the real parts in your equation, and the imaginary parts in your equation:
[tex]\frac{\frac{r}{wc}}{r^{2}+\frac{1}{(wc)^{2}}}=-951[/tex]
And:
[tex]-\frac{\frac{r^{2}}{wc}}{r^{2}+\frac{1}{(wc)^{2}}}=-13026[/tex]
To solve for both c and r, you can use the following steps:
1. Multiply both sides of the equation by the denominator (r^2 + (1/(wc)^2)) to get rid of the fraction on the left side.
2. Simplify the left side by using the distributive property. This will give you a new equation with only c and r variables.
3. To get two equations, you can substitute different values for r and c in the new equation. For example, you can substitute r=0 and solve for c, then substitute c=0 and solve for r. This will give you two equations with one variable each.
4. Once you have the two equations, you can solve them simultaneously using algebraic methods such as substitution or elimination.
Alternatively, you can also use a system of equations solver or a graphing calculator to solve for both c and r simultaneously.
