Is My pH Calculation for HCl and NaOH Solution Correct?
  • Thread starter Thread starter Mathman23
The discussion centers on the pH calculation for a solution containing 100 mL of 0.102 M HCl and 100 mL of 0.0780 M NaOH. The initial calculation by Fred indicated a pH of 1.05 based on the concentration of H3O+ ions. However, upon further analysis, it was determined that after neutralization, the remaining moles of HCl resulted in a concentration of 0.012 M H+, leading to a corrected pH of 1.92. The calculations were verified as accurate, confirming the proper application of pH formulas and neutralization principles.
  • Understanding of acid-base neutralization reactions
  • Knowledge of pH calculation methods
  • Familiarity with molarity and concentration calculations
  • Basic chemistry concepts related to hydronium ions (H3O+)
  • Study acid-base titration techniques and their applications
  • Learn about the Henderson-Hasselbalch equation for buffer solutions
  • Explore the impact of temperature on pH measurements
  • Investigate the role of ionic strength in pH calculations
Chemistry students, laboratory technicians, and anyone involved in chemical analysis or pH measurement will benefit from this discussion.
Mathman23
I have calculated the PH-value for this following solution:
100 mL 0,102 M HCL and 100 mL 0,0780 M NaOH.
To calculate the pH in the this solution first I must calculate the number of moles [itex]n_{[H_3O^+]}[/itex].
[itex]n_{[H_3 O^{+}]} = 0,100 L \cdot 0,0102 \ mol/L + 0,100 L \cdot 0,0780 mol/L = 0,018 mol[/itex]
This means that [itex][H_3 O^{+}] = \frac{0,018 mol}{0,200 L} = 0,09 mol/L[/itex]
pH for the solution is then [itex]pH = \textrm{-log}(0,09) = 1,05[/itex]
I would appreciate if somebody would look at my calculation and then tell me if its accurate ??
Many thanks in advance.
Sincerely
Fred
No. of moles of HCl in 100mL, 0.102 M soln. = 0.0102
No. of moles of NaOH in 100mL, 0.078 M soln. = 0.0078
So, a neutralization takes place and the number of moles of HCl that remain = 0.0102-0.0078=0.0024.
The concentration of H+ ions is 0.0024/0.200 = 0.012M
So, pH=-log(0.012)=1.92
spacetime
www.geocities.com/physics_all
Hi Fred,
Thank you for sharing your calculation for the pH value of the given solution. Your calculation appears to be accurate and follows the correct steps. You correctly calculated the moles of HCl and NaOH in the solution and then determined the concentration of H3O+ ions using the volume and moles. Finally, you calculated the pH value using the formula pH = -log[H3O+].
I would suggest double-checking your calculations and units to ensure accuracy. Also, make sure to include the correct units in your final answer, which would be pH = 1.05 (without units).
Overall, your calculation seems to be correct. Great job! Keep up the good work.
  • · Replies 22 ·
