Question regarding units of some magnetic quantities
The discussion revolves around the distinctions between various magnetic quantities, specifically magnetic field strength and magnetic flux density, as well as their respective units, including Tesla, Oersted, and Weber. Participants explore theoretical and conceptual aspects of these quantities.
  • Some participants note that the Halliday-Resnick textbooks refer to the strength of a magnetic field in SI units as Tesla, while other sources mention Oersted for magnetic field strength.
  • One participant suggests comparing the quantities in terms of fundamental units (Time, Length, Mass, Charge) to clarify differences.
  • There is mention of J.D. Jackson's "Classical Electrodynamics," which states that the unit of magnetic field strength is Henry, equating it to 10^4 Oersted, highlighting the distinction between SI and Gaussian unit systems.
  • Participants express confusion regarding the units, particularly the use of Henry for inductance and its relation to magnetic field strength.
  • Clarifications are made that magnetic flux density is represented by B (Tesla) and magnetic field strength by H (Ampere per meter), with conversions provided between SI and Gaussian units.
  • One participant explains that H can be derived from B by multiplying by the permeability of the medium, with specific reference to free space.
  • There is acknowledgment of confusion in nomenclature, particularly with Jackson's terminology, which refers to magnetic flux density as "magnetic induction."
  • Another participant confirms that 1 Tesla is defined as 1 Weber per square meter, reinforcing the distinction between flux density and magnetic field strength.
Participants express varying levels of understanding and confusion regarding the distinctions between magnetic field strength and magnetic flux density, as well as their units. There is no consensus on a singular explanation, and multiple viewpoints are presented.
The discussion highlights limitations in understanding due to the complexity of unit definitions and the potential for confusion arising from different systems of measurement (SI vs. Gaussian). Some assumptions about the relationships between quantities and their units remain unresolved.
Brad Barker
In the Halliday-Resnick textbooks, there is only mention of strength of a magnetic field, which in SI units is the derived unit Tesla.
However, on my TI-89 and on more modern sources on the internet (including a Fuji-film PDF!), there is mention of the unit of the Oersted for magnetic field strength. The units of Tesla (and the related unit, Gauss) are reserved for something called "Magnetic Flux Density," which for reasons unknown to me is considered separate. The unit for Magnetic Flux is, as usual, the Weber.
So...does anyone have any information regarding the distinctions between these two quantities?
A good place to start is to write all of the quantities in terms of the fundamental units, Time, length, Mass and Charge. Now compare, this should make the differences obvious.
i'm not sure what course you're doing but you will find such info in many books on electromagnetics. J.D. Jackson Classical Electrodynamics has the unit of magnetic field strength as a Henry (H) = 10^4 Oersted (Oe) Henry is in the SI unit system and Oersted is in the Gaussian unit system
if you're actually asking what is the difference between a flux density and a field, then that is another matter; what exactly do you mean?
i thought that the Henry was the unit for inductance. now I'm even more confused.
i was also asking about what the difference is between magnetic field strength and magnetic flux density.
i figured that the magnetic field strength would be the "B" in:
F = qvB sin(theta)
The unit for this, as far as I've seen in the textbooks I've come across (the most renowned of which being Halliday-Resnick), is the Tesla, where:
1 T = 1 N-s/C-m.
...And magnetic flux is given by:
phi = BA cos(theta)
(these, of course, just being the equations for the magnitude.)
so...what's the deal?
Brad Barker said:
i thought that the Henry was the unit for inductance. now I'm even more confused.?
oops sorry in Jackson's appendix (p. 783), the unit for inductance is given on the line two lines below that for magnetic field.
as you rightly point out the SI unit for inductance is 'henry' or 'H' for short; whereas the SYMBOL for magnetic field is the symbol 'H' with its unit being 'Amp metre^(-1)'
in summary
magnetic flux density is symbol B SI unit tesla = 10^(-4) gauss
magnetic field is symbol H SI unit A m^(-1) = 4*pi*10^(-3) oersted
those last convertsion are from SI to the older Gauassian system of units
F = qvB sin(theta)
1 T = 1 N-s/C-m.
phi = BA cos(theta)
ok, B is a SI magnetic flux density (tesla) A is area m^2 in SI, cos(theta) dimensionless in whatever units you choose.
ok?
so let's answer you actual question: what is the difference between a magnetic flux density (B) and a magnetic field (H)?
well in its simplest form, you get H by multiplying the B by the permeability of whatever medium you're working in; if it's free-space then its symbol is mu_0 ("mu nought") and it converts between the two: in SI units
H=mu_0*B
where mu_0 equals 1/(4*pi) * 10^(-7) H m^(-1)
I might add that there's some confusion because Jackson the paragon of electromagnetic correctness points out that there IS confusion due to the nomenclature; further, Jackson calls magnetic flux density "magnetic induction" and defines magnetic flux in units of 'Weber' (with symbol phi, or F) just to REALLY confuse us both!, so look up the answer and work backwards if you can (LOL)
fun aint it! so hence you see the need for standards committees, huh?
finally, in maths, a flux usually is defined in terms of a quantity going through an area and so B would multiplied by the area A to give force is pretty much what your reference says also
You are correct Henry is the unit of inductance, not the Magnetic field, which is indeed Oresteds. Perhaps the confusion occurs because H is the commonly used sybol for the Magnetic field, and it is also the appreviation for Henrys, but they are not the same thing.
The unit of flux is the Weber, and 1 Tesla is 1 weber per square meter exactly, by definition. So Tesla, as units of B, is a flux density.
thanks, tfleming. that clears it all up. so, the oersted isn't an SI unit after all but is instead gaussian.
H = mu B.
  • · Replies 0 ·
21K
13K
36K
