How Does Cross Sectional Area Affect String Wavelength Calculation?
  • Thread starter Thread starter buffgilville
    String Wavelength
The discussion focuses on the relationship between cross-sectional area and wavelength calculation for a string under tension. A cable with a density of 8850 kg/m³ and a cross-sectional area of 9.6 mm² is subjected to a tension of 103.4 Newtons and oscillated at a frequency of 480.1 Hertz. The correct wavelength calculation, derived from the wave equation, is confirmed to be 0.0727 meters, correcting the initial miscalculation of 2.25E-4 meters. The cross-sectional area is essential for determining the mass per unit length of the string, which directly influences the wavelength.
  • Understanding of wave equations and their components
  • Familiarity with linear mass density calculations
  • Knowledge of tension in strings and its effects on wave properties
  • Basic grasp of units of measurement (e.g., converting mm² to m²)
  • Study the derivation of the wave equation for strings
  • Learn about linear mass density and its calculation from density and cross-sectional area
  • Explore the impact of tension on wave speed and wavelength
  • Investigate practical applications of wave properties in engineering contexts
Students and professionals in physics, engineering, and materials science who are interested in wave mechanics and string dynamics.
buffgilville
1) A cable made from a metal of density 8850 kG/cubic meter, and whose cross sectional area is 9.6 cubic mm is pulled to a stress of 103.4 Newtons. One end of the string is oscillated with a frequency 480.1 Hertz. The wavelength of the wave on the string (in meters) is
T=f^2 * linear mass density * wavelength^2
T=103.4 Newtons
linear mass density = 8850 kG/cubic meter
f=480.1 Hertz
so, I plug all those in and got 2.25E-4
but the correct answer is 7.27E-2
The question gave a cross sectional area. How does that relate to the wavelength?
T=103.4 Newtons
f=480.1 Hertz
I assume the cross-sectional area is 9.6 square mm, not cubic. The area is needed to calculated the mass per unit length of the string.
The wave equation is given by:
[itex]\lambda \nu = \sqrt {\frac{T}{M / L}}[/itex] where M/L = mass per unit length which is density x area
[tex]\lambda = \frac{\sqrt{T/ \rho A}}{\nu}[/tex]
[tex]\lambda = \sqrt{103.4/8850 \times 9.6 \times 10^{-6}}/480.1[/tex]
[tex]\lambda = \sqrt{103.4/.08496}/480.1[/tex]
[tex]\lambda = 34.886/480.1[/tex]
[tex]\lambda = .0727 m[/tex]
AM
Thanks Andrew Mason!
13K
  • · Replies 19 ·
